4x4 Keypad — Parallax Forums
4x4 Keypad
jayzdabossjayzdaboss Posts: 18
edited 2012-01-22 05:57 in Robotics
I need help programming my keypad.
  • LeonLeon Posts: 7,620
    edited 2012-01-21 10:52
    What is it connected to?
    What keypad? With what controller? What have you tried so far?
  • jayzdabossjayzdaboss Posts: 18
    edited 2012-01-21 11:18
    Basic stamp
    edited 2012-01-21 11:20
    Haven't tried anything cuz I have no idea how I'm suppose to get it to work I'm just getting started
    edited 2012-01-21 18:49
    If this is the Parallax membrane keypad the product pages has a pdf which shows how to use it. But a summary would be that you put 1k resistors on the column leads and hook them to i/o pins. You then hook the row leads up to i/o pins. From there you put the column pins into output and then row pins into input. Sweep through the columns and read the rows.
    Martin_H wrote: »
    Thanks that was great help.
