Alternative Serial Displays — Parallax Forums
eagletalontimeagletalontim Posts: 1,399
edited 2012-01-27 21:50 in Propeller 1
Hello all once again! I have a project that is currently using the 16 X 2 back lit serial display from Parallax. I plan to market my completed project but I would like to get the cost down as much as possible. Right now, I am hoping to find a serial display that will work with the prop that is not $30 a piece (no offense to Parallax!) Since the serial display only takes up 1 pin, I would like to stay with that if at all possible. Does anyone have some recommendations of where I could find cheaper displays?
    edited 2012-01-20 20:13
    I like the 117 chip which can, be paired with any parallel lcd to make a serial lcd
    http://www.phanderson.com/lcd106/lcd107.html
    edited 2012-01-20 20:17
    Quickly typing in "serial 16x2 lcd" into ebay comes up with prices as low as $22 including shipping. You can probably do better if you buy in multiple quantities.
    The serial ones do seem to be more expensive than the parallel ones, but if you only have one pin left... (hands up who wants more pins on the propeller?!)
  • eagletalontimeagletalontim Posts: 1,399
    edited 2012-01-20 20:24
    I try to stay away from ebay as much as possible. I have been burned several times on there. My luck I guess. Since I will hopefully be selling the completed project, I need stability on where I can order from. I have been selling the previous version of my product going on 4 years. This is a new and improved version which I hope will catch the market's eye. Price is going to matter since most of my market buy's on price. Competition has just arrived and has blown my price away... I have not had a sale in over 2 weeks and I can't match his price, but I can beat his product with functionality and more. With a $30 price my cost added to each product, it will put a slight hurt on my competitive edge.
    ... I put my hand up as well :)
    edited 2012-01-20 20:33
    Wow... That is nice looking!
    http://search.digikey.com/us/en/products/M0216SD-162SDAR2-1/M0216SD-162SDAR2-1-ND/1739768
    I am hoping for a black background with different color options for the characters. One color per display though... I don't know what they are called if they are even called anything special.
    I must say I have never used serial LCD displays as they cost too much. I use parallel ones (same commands, same chipset) and use latches. There are many solutions and I've gone for one that uses the lower 12 propeller pins through latches to give 64 digital I/O. Latch chips are under $1.
    Or you could use 3 pins and use HC595 chips.
    Or 3 pins and drive a TV screen ("car reversing" displays are under $30 and propeller objects work out of the box).
    And I think Cluso did a TV driver that had two colors and one pin. Fine if you just want to display text.
    What is the display for?
    edited 2012-01-20 20:36
    The display will be for an automotive application so I want it to look professional. The green back lit displays to me don't look professional for a product that I would sell. They look more like a project use display. I have searched google and have not found anything with a decent price on it. If the display is going to be the most expensive part, then I guess it will have to be that way. I just want it to be as professional as possible.
    I will also need some sort of enclosure with the display to allow customers to mount the display anywhere they want in their vehicle away from the "main brain".
    I just found this, but I really have no idea what I am looking at when it comes to communication between the chip and the display. http://www.seeedstudio.com/depot/lcd-204-characters-white-back-light-p-350.html?cPath=163_164
    A 20 X 4 for $16.50.... that is really cheap.. question is, would it work with the Prop and if so, what driver would I need?
    edited 2012-01-20 20:51
    Tim,
    Check out this Futurlec link. www.futurlec.com/LCDDisp.shtml
    While these are all parallel displays, there are many objects for devices based on this chip including a three-wire Object I put up. Also, someone also posted they could go a bit further and do it with one wire. If you can get by with 16*4, they get a bit cheaper. I don't think green is unprofessional, even fluke used green back lighting in their Kiethley dose measuring systems. If you are looking at cool, consider blue back light.
    Good luck,
    Frank
    edited 2012-01-20 20:59
    Yes that will work with the propeller. There is a driver in the obex. I've written drivers as well but they use a latched solution rather than driving the display directly.
    Below is a little terminal I wrote for a 20x4 display. It outputs via a latch but only uses 6 pins, so you could easily change the PUB LCDOutput so it outputs directly from 6 propeller pins. Just a few lines of spin code to change.
    These displays are all very similar - they can run in "4 bit" mode so you split a byte into two and send it out in two parts. Then there are two control pins. So 6 pins in total.
    '' parallel 20x4 lcd driver for the DracBlade including a 'Terminal' that scrolls properly, backspace etc
    CON
      _clkmode      = xtal1 + pll16x                        ' use crystal x 16
      _xinfreq      = 5_000_000
      LatchDirection =%00000000_00000000_00001111_11111111 ' 138 active, gate active and 8 data lines active
      MaskLowByte =   %00000000_00000000_00000000_11111111 ' used in lots of routines to & mask off low byte
      LCDLatch =      %00000000_00000000_00001011_00000000 ' LCD latch is xxxx101x and gate high xxxxxxx1
      EnableBit =     %00000000_00000000_00000000_00000010 ' Enable pin 6 on LCD displays
    OBJ
     delay    : "timing"
    VAR
    long Char                       ' Character To Send To LCD
    long Inst                       ' Instuction To Send To LCD
    long Column                     ' column counter for line 4 ' don't use byte, causes all sorts of overrun errors
    long LineNumber                 ' line number 1,2,3,4
    long LCDChar                    ' character to send to LCD 0-$FF
    long LCDByte                    ' byte to latch out to LCD display
    byte Display[79]                ' buffer for display 20x4  ' put this last as bizarre overwriting going on
    PUB Start  | n
        Init_Lcd
        Column:=0                                           ' start at zero
        repeat n from 0 to 79                ' fill the display memory with spaces
          Display[n]:=" "         'fill with spaces
        Redraw
        repeat 25        ' test code for running standalone
          out(65)
        out(10)
        out(66)
        out(13)
    PUB str(stringptr)
    '' Print a zero-terminated string
      repeat strsize(stringptr)
        out(byte[stringptr++])
    PUB dec(value) | i '' Print a decimal number
      if value < 0
        -value
        out("-")
      i := 1_000_000_000
      repeat 10
        if value => i
          out(value / i + "0")
          value //= i
          result~~
        elseif result or i == 1
          out("0")
        i /= 10
    PUB hex(value, digits) '' Print a hexadecimal number
      value <<= (8 - digits) << 2
      repeat digits
        out(lookupz((value <-= 4) & $F : "0".."9", "A".."F"))
    PUB bin(value, digits)
    '' Print a binary number
      value <<= 32 - digits
      repeat digits
        out((value <-= 1) & 1 + "0")
    PUB out(c) | i,j
    ' Output a character, ignores most <32 and all >126
    ' possibly add a 'turn on display' and 'turn off display' with selected ascii characters ?? esc seq
        i:=c ' need a local working variable as an if statement seems to corrupt subsequent working variables!
        j:=Column ' and need a local version of column otherwise corrupts this too
        if c==10                                              ' Linefeed
            Newline
            Column:=0                                           ' reset column counter
            j:=21                                               ' ensures code below doesn't run
        if j<20 ' this LCD driver code is slow so better to not print anything after line 20 and wait for CRLF
    '    if j > 19                                      ' is it off the end of the display? (old display wrapped around)
    '      Column:=0                                         ' reset to beginning
    '      Newline
          if c==08                                              ' Backspace
            Backspace
    '      if c==13                                              ' do nothing as LF includes CR as part of the code
          if i >= 31                                              ' and statements don't work in if lines?!
            if i<=126                                             ' send the ascii character
              char := c                                           ' get the character
              Send_Text                                           ' send it out
              Display[Column+60]:=c                                  ' store the character in the last column
              Column:=Column+1                                    ' add 1 to column
         if j==19
            CursorOff
    PUB CursorOn
      Inst:=13                                              ' turn on the cursor
      Send_Inst
    PUB CursorOff
      Inst:=12                                          ' cursor off
      Send_Inst                                         ' send the instruction
    PRI  Init_Lcd
        LCDLow                                              ' set the 6 LCD lines low
        delay.pause1ms(200)                                 ' short delay for LCD bootup 200ms
        LCDByte:=%00001100                                  ' send out 0011 already shifted to xxnnnnxx
        PulsOut
        PulsOut
        PulsOut
        LCDByte:=%00001000                                  ' send out 0010 already shifted to xxnnnnxx
        PulsOut
        PulsOut
        LCDByte:=%00100000                                  ' send out 1000 already shifted to xxnnnnxx
        PulsOut
        Inst:=14                                            ' cursor on
        Send_Inst
        Inst:=1                                             ' cls
        Send_Inst
        Inst:=13                                            ' flashing cursor
        Send_Inst
        Inst:=128                                           ' to position 1
        Send_Inst
    pri Send_Inst ' send instruction in Inst
        RSLow                                                      ' not actually needed see below but makes code more logical
        LCDByte:=Inst                                              ' get high nibble
        LCDByte:=LCDByte>>2                                        ' shift right two bits so xxnnnn00
        LCDByte:=LCDByte & %00111100                               ' mask the nibble and sets RS low as well (bit0)
        Pulsout                                                    ' send it out
        LCDByte:=Inst                                              ' get low nibble
        LCDByte:=LCDByte<<2                                        ' shift left two bits so xxnnnn00
        RSHigh                                                     ' back to text mode
    pri Send_Text ' pass Char = a byte
       'RS always high = bit 0, bits are xxnnnnER where nnnn is the nibble, E=enable and R=RS
       LCDByte:=Char
       LCDByte:=LCDByte & %00111100                         ' mask off just the nibble
       LCDByte:=LCDByte | %00000001                         ' keep RS high
       LCDByte:=Char                                        ' get low nibble
       Pulsout
    pub Next_Line
        Inst := %11000000                         ' Move Cursor To Line 2
        Send_Inst
    PRI ToggleGate
       OUTA[8]:=0                                            ' set gate pin low
       OUTA[8]:=1                                            ' and high again - may need a delay in PASM
    PRI EnableLatchPins
        DIRA:=LatchDirection                                ' 138 active, gate active and 8 data lines active
    PRI Tristate ' tristate all pins
      DIRA:=%00000000_00000000_00000000_00000000
    PUB LCDOutput | n ' sends byte LCDByte to latch
       EnableLatchPins ' turn on the pins needed to talk to the latches
       n:=LCDByte                                           ' byte value to send out
       n:=(n & MaskLowByte)                                 ' 2 AND mask the low byte
       n:=(n | LCDLatch  )                                  ' 3 OR with the LCD address 138
       OUTA:=n                                              ' 4 send it out
       ToggleGate                                           ' 5 and latch it
       tristate ' back to tristate on all pins
    PUB LCDLow ' sets all LCD pins low for startup
       LCDByte:=0
       LCDOutput
    PUB PulsOut ' pulse the enable pin 6 high then low - uses LCDByte and returns it unchanged
       LCDByte:=(LCDByte | %00000010)                       ' logical OR  to set just this bit high
       LCDOutput                                            ' send it out
    '   delay.pause1ms(1)                                    ' short pause not needed as spin very fast
       LCDByte:=(LCDByte & %11111101)                       ' logical AND set just this bit low
    '   delay.pause1ms(1)                                    ' delay for LCD to process it
    PUB RSHigh  ' set RS pin 4 high - uses LCDByte and returns it unchanged
       LCDByte:=(LCDByte | %00000001)                       ' logical OR  to set just this bit high
       LCDOutput
    PUB RSLow ' set RS pin 4 low - uses LCDByte and returns it unchanged
       LCDByte:=(LCDByte & %11111110)                       ' logical AND set just this bit low
       LCDOutput
    PUB Backspace | i,j
    ' backspace is a special case - need to subtract 1 off the column, make the last character a space
    ' and redraw the screen and print out column number of characters on last line
    ' only really works on line 4 but most of the time the display is on line 4 anyway
        j:=Column                 ' the last character added 1 to column so start with one less
        if j>1                      ' not reliable at 1
          Display[Column+60-1]:=32    ' was one past the character
          Column:=Column-1            ' subtract 1
          Redraw
          repeat i from 0 to j-2
            Char:=Display[60+i]        ' print out the last row with one less character
            Send_Text
    PUB Redraw                        ' redraw the entire screen
        Inst:=128                     ' line 1
        Send_Inst
        LineNumber:=1                 ' print line 1
        Printline
        Inst:=192                     ' line 2
        Send_Inst
        LineNumber:=2                 ' print line 2
        Printline
        Inst:=148                     ' line 3
        Send_Inst
        LineNumber:=3                 ' print line 3
        Printline
        Inst:=212                     ' line 4
        Send_Inst
        LineNumber:=4                 ' print line 4
        Printline
        Inst:=212                     ' cursor to beginning of line 4
        Send_Inst
        CursorOn
    PUB PrintLine | n                   ' Prints the line in LineNumber 1 to 4
        n:=(LineNumber-1)*20                ' convert to pointer for the array 0-79
        repeat 20                       ' do this 20 times
          Char:=Display[n]              ' get the character from the array
          n:=n+1                        ' increment counter
    PUB Newline | i ' move the lines all up one, clear line 4, move cursor to position 1 of line 4
        repeat i from 0 to 59                                            ' move up to next line
          Display[i]:=Display[i+20]
        repeat i from 60 to 79
          Display[i]:=32                                    ' space
        Column:=0                                           ' column counter to zero
        Redraw                                              ' redraw the screen
    edited 2012-01-20 21:16
    Wow.. that is a lot more to work with! Parallel may be cheaper, but additional components to drive it along with shipping will just about cost as much as a serial display.
    This is basically what I am hoping to find that would hopefully be a direct replacement for the parallax 16 X 2 display.
    https://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_2137764_-1
    As of right now, I have 9 more pins open on the Prop. 8 of them are driving a 7 segment display which takes up quite a bit already. Since I would like to allow users to plug in their own addons to the product, I need to have at least 5 open pins for them to have access to. I am still in development stages and I will probably need 3 or 4 more pins to complete a few more features.
  • Brian RileyBrian Riley Posts: 626
    edited 2012-01-20 22:01
    A PCB and complete kit with/without display, based upon the Anderson 117 chip ...
    http://www.wulfden.org/TheShoppe/k107/index.shtml
    edited 2012-01-20 22:59
    That jameco display is an OLED. They look stunning - much clearer than LCDs and visible from all angles. They do make a project look a lot more professional.
    Re serial vs parallel, you only need 6 pins to drive these displays. So that can be 6 propeller pins. Or you can share some pins with something else (eg your 7 segment display - blank the display briefly while you output data), or use a 74HC595 which reduces the pin count to 3 pins (45c at jameco).
    In serial mode it is using 4 pins and looks like a standard SPI interface. CS would always be enabled so maybe 3 pins? Maybe even 2 pins because you could ignore data coming back from the display.
  • JonnyMacJonnyMac Posts: 9,773
    edited 2012-01-20 23:46
    If you have the IO your least expensive bet is going straight parallel interface. You can even share LCD buss pins with buttons if you're shot of IO. I and others have written good LCD drivers for 4-bit parallel mode.
    edited 2012-01-21 00:19
    Dr_Acula wrote: »
    I saw this thread earlier and I was just about to suggest the same thing.
    Daisy chain two 595s together and drive both the 7-segment and LCD with 3 pins. If you don't your competitor will likely do it.
    Has anyone driven a LCD with a shift register? I wouldn't think it would be very difficult.
    Tim, I think you ought to give eBay another try. Just buy a few low cost items from a seller to make sure they're legitimite and then order larger batches from the same seller once you're comfortable with the seller.
    Here's a $3 LCD. The $3 includes shipping. An awfully safe bet. (I've personally purchased many items from this seller (including this LCD).)
    I think the reason you don't find inexpensive serial LCDs is because there made for hobbiests. People like us who are willing to pay extra for the simplicity of a serial interface to use in our one-off creations. I really doubt there are serial LCDs being used as components in high volume products.
  • RDL2004RDL2004 Posts: 2,554
    edited 2012-01-21 05:43
    Be aware of potential visibility issues. Automobiles tend to be brightly lit during the day and some back lit LCDs (transmissive) are hard to read under bright light. You may want to look a VFD or OLED. However, OLEDs are known to have burn-in issues (well, all displays have aging problems to some degree). Microtips makes a high brightness LCD they call Vivid (VLCD), but I haven't had a chance to see one in person. NewHaven sells direct from their web site, and has a large variety of displays including OLED and VFD, some are I2C compatible.
    Link to Microtips .pdf on VLCD vs. VFD
    Link to www.newhavendisplay.com
    edited 2012-01-21 07:03
    I like the Newhaven displays as well - I used THIS ONE in my VMUSIC2 project
    edited 2012-01-21 08:25
    I do kind of like the white on blue look :) Since I have apparently run out of room on my 16x2 display, It looks as though I need a bigger one...
    This on : http://www.newhavendisplay.com/index.php?main_page=product_info&cPath=253&products_id=2391 looks pretty nice, but, question is, would I be able to use the LCDupdate code Dr_Acula posted with this display? I also need an enclosure to put just the display in. Are these made to fit in already made enclosures readily available on the web?
    edited 2012-01-21 08:58
    I don't know if it matters much for automobiles, but I'm pretty sure airplane cockpit lights are red since red light interferes less with night vision.
    I suppose a car has plenty of other light sources to spoil ones night vision. I'm just wondering if the color of light used with the display should be a concern or not?
    Come to think of it, I think I've seen a lot of blueish car displays in the past so it probably doesn't matter.
    edited 2012-01-21 09:24
    I have one of those as well. I wrote an OBEX driver that will work with the 16x2 or 20x4 http://obex.parallax.com/objects/798/
    I have never come across enclosures made for LCDs...
  • richaj45richaj45 Posts: 179
    edited 2012-01-21 13:36
    Dr_Acula, a quote form you.
    "There are many solutions and I've gone for one that uses the lower 12 propeller pins through latches to give 64 digital I/O. Latch chips are under $1."
    Would you be able to share the schematic and idea for your 12 to 64 bit io interface.
    Thnaks
    Rich
    edited 2012-01-21 14:47
    Duane Degn wrote: »
    Duane,
    The object "3 I/O Pin Hiatchi Compatible LCD Driver" is based on a PowerTip PC2400LRF (just another hitatchi compatible clone LCD display) and one 74xx164 shift register.
    As to going with ebay, that is fine as far as the initial development or for a personal one off. Tim however will be looking at production runs (even if not many to start). He will need reliable sources of current parts to support production and eventually repairs. eBay is loaded with pulls, overstock, and closeouts that may not be available reliably for future production.
    Frank
    edited 2012-01-21 15:54
    Sure. I don't have access to schematics on this computer, but essentially take 8 propeller pins and call this a bidirectional bus and connect to latches for outputs or 244 chips for inputs. Each of those chips has a 'chip enable' pin that enables the pin when it goes low. Use 4 propeller pins to drive a 138. Three pins select which of 8 outputs goes low. The fourth pin enables the 138, so you can make all pins high and disable all outputs.
    If you are ok about 64-8 = 56 i/o pins, you could do this with 11 pins instead of 12.
    There are many options for driving displays. To me, just using 6 pins on the propeller seems simplest.
    There are many sources for 20x4 LCD displays (I like the white on blue ones) so if one supplier can't get them, many others can.
    edited 2012-01-21 16:50
    That is pretty interesting stuff. I would be nice if I could create my own serial input board that connects to the parallel input of the LCD screen. Then I could put my own custom logo in the display for the boot screen that would not be modifiable by others. It seems the parallel LCD are cheaper, but by the time I add in all the other circuitry to use it, they cost about the same as a serial display. I have yet to find a 1 wire LCD display like the one Parallax offers only in different colors. That would be the best option right now.
    edited 2012-01-21 18:26
    You might have a look at the Electronic Assembly EA-DOG series. They're really thin, available in various colors, and at $12 (for a single) they're fairly cheap. (You order the backlight separately for about $6). They have multiple interfaces on board - 4 or 8 bit parallel, or SPI.
    http://www.mouser.com/electronicassembly/ (2nd item on the list)
    I have two of them, but haven't actually tried them yet.
    Jason
    edited 2012-01-21 18:27
    I just found this which is really nice, and it comes with an enclosure which is exactly what I am needing.... but..... It uses way more pins than I have available. Very nice though!
    http://www.bgmicro.com/ncrfutaba4x20vacuumfluorescentdisplay.aspx
    edited 2012-01-21 19:08
    Well, it appears as though there is not a simple pre-made enclosure for any 2x16 of 4x20 lcd display :( I have been all over the web searching for a small box to house just the display with no luck at all. If anyone knows of one, please let me know!
    If there are none, what other displays are there that have an enclosure it will fit right into? This is for an automotive application so it has to be durable.
  • CircuitsoftCircuitsoft Posts: 1,166
    edited 2012-01-21 19:13
    96x128 Graphic OLED is $15 from SparkFun. It can run on i2c, so it'll share i/o pins with the EEPROM. With the in-ROM font on the propeller, you'll get two lines and eight characters per line, but you could scale the font down a lot. It is, however, .96" diagonal.
    edited 2012-01-21 19:27
    yeah, that is a little small for what I need. It would also need an enclosure that it would fit directly into.
    The idea that I have is to have a main brain that does all the processing and computing for my product. A user can connect an external LCD display to place anywhere they want in their vehicle. There is also an external 7 segment display that will be connected to the main brain that will be a quick reference for the user to look at when needing to see what gear they are in. I may be able to eliminate the 7 segment display and open up 8 pins on the prop to allow for a more powerful display if needed. Cost is the biggest thing at the moment though!
    edited 2012-01-21 21:12
    Since this display : http://www.bgmicro.com/ncrfutaba4x20vacuumfluorescentdisplay.aspx is the only display I can find with an enclosure that allows for a "stand alone" type display, would this be able to work with the Prop. There are Arduino examples, but I have not found any for the Prop. I am pretty new to the Prop Spin and Assembler language so I don't have the knowledge to write my own LCD code :( I am learning though!
    edited 2012-01-21 23:28
    You would be doing yourself a tremendous service by making the attempt. So many newbies want to find ready-made solutions for every problem and they just do not exist. The good news is that programming is programming, and if someone's done it on an Arduino you can generally port it to the Propeller without much pain -- I do it all the time.
  • bsnutbsnut Posts: 521
    edited 2012-01-22 00:22
    I agree with Jon's point. What I will do is look at the datasheet for this display, the Arduino code and the Propeller code for Parallax display that is similar to this display you have and compare the two, which should give an idea how to write your code.
