Servo Torque Question
After looking up data about servos I might use for a project I am working on I notice that they all seem to have a range of voltages that they would work at. And they also seem to correlate the amount of voltage being applied to how much torque is maintained. The project I am trying to start would require the use of at least 8 or so servos (not 100% sure how many exactly yet). I would be using the propeller servo controller usb (http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/28830-PropServoControllerUSB-v1.0.pdf) to control the servos. So if I plugged in 7.5V to the propeller servo controller usb, and the maximum voltage for the servos I plug in in 7.5 volts, would they all be operating at the maximum torque or would it be reduced because I using that 7.5 volts to cover multiple servos? Also, if the maximum voltage for the servos was only 5.5V and I plugged in 7.5V to the propeller servo controller would that damage the servos even if I had multiple servos plugged in (I'm pretty sure the answer is 'yes it would', but I just want to make sure.)
I hope I explained that well enough. If not, please let me know and I can try to reword and explain more.
Thanks!
EDIT: Also is there any circumstance to which I should use any other type of battery than just standard batteries, like duracell or something like that. (Ni-Cd, Ni-MH, LI-Ion)?
Thanks!
I would avoid over voltage of the servos as it will likely decrease their life. But I've done it and my servos survived.
For high current draw use NiMH or LiPo.
