Bedside table / remote controlled lamp
JasonDorie
After seeing the remote controlled lamp I made, a friend mentioned she wanted a reading lamp / nightlight, and a surface, like a bedside table without drawers, to put her phone, alarm clock, etc on. She sent me a pic of what looked like a small black skyscraper and said she wanted it to look like that.
I finished it this evening. It's using a Propeller Protoboard as the controller, has an infrared remote sensor connected via JonnyMac's Sony IR reader, and a PWM object I wrote to drive the two LED supplies.
The LED driver boards are these: http://www.sparkfun.com/products/9748
They're unique in that you can't drive them high / low like normal PWM - you have to drive them low / floating, which means toggling the pin between an input and an output, instead of toggling the pin value itself.
Each of the two driver modules is connected to 3 high-power LEDs. Each driver puts out 650ma @ 12v. Each LED puts out about 200 lumens, or 1200 total for all 6. The whole shebang is hidden inside a custom box I cut with my CNC with a thin sheet of HDPE acting as a diffuser.
The lamp operates basically identically to my previous remote controlled lamp (I just ported the code and made a few tweaks). It looks really cool, and slightly ominous.
Pics below.
Pics below.
That is very cool! It's like a modernized version of Japanese styled lantern tables.
Excellent work blending hobbies!!
