TCS3200-DB Focal Length and Ambient Light
I know the TCS3200-DB has a focal length, but will this affect readings for ambient light? As in, if I am trying to measure ambient light, can I just leave the DB exposed, or do I need to position a lens or something at the focal point? Thanks!
Please tell us more about your project, and it will be easier to provide a more precise answer.
See the TCS3200-DB docs or the TCS3200 datasheet for info about the internal dividers. They are controlled by the S0 and S1 inputs which are, by default, pulled high on the TCS3200-DB module.
Actually I erred with my remove-the-lens advice. I had neglected to consider that the lens includes that all-important IR filter. This is important, because IR will pass right through all of the color dyes that form the sensor's internal filters. So leave the lens on and aim it at a piece of white paper.
Try it with all the settings, starting from the highest ratio, and working your way down. If you reach a point where the reading is too low, compared to the what you'd expect from the prior readings, you've gone too far. For example, if you get 144,000 counts at a setting of 2, and 200,000 counts at a setting of 1, you'll know that your MPU can't keep up at the latter setting, because you should have gotten 288,000.
One side of the diffuser has a "frosted" finish (ground glass side), while the other side has a shiny, smooth finish. Which side should be in contact with the lens, and which should be facing up (away from the lens) to get the best results? I would guess the ground glass side down (in contact with lens), but want to double check. Thanks for your help.
Are you asking about the wavelengths to which the photodiodes are sentive? If so, there are spectral response curves on page 5 of the documentation.
