repeat 'loop indefinately
if numChars > 20
repeat i from 0 to 19 'increment in
MoveTo(20-i, row)
repeat txt from 0 to i
char := byte[@_theText][txt]
LCD.STR(@char)
waitcnt(clkfreq / _delay + cnt)
Clear
repeat i from 1 to (numChars - 19) 'full line
MoveTo(1, row)
repeat txt from i to (i + 19)
LCD.STR(@char)
Clear
repeat i from (numChars-18) to numChars 'increment out
MoveTo(1, row)
repeat txt from i to numChars
LCD.STR(@char)
Clear
[/php]
vs [html] tags
[html]PUB main | col, loop, row, char, txt, i, start, end
if numChars > 20
MoveTo(20-i, row)
LCD.STR(@char)
Clear
MoveTo(1, row)
LCD.STR(@char)
Clear
MoveTo(1, row)
LCD.STR(@char)
Clear
So I played around some last night with making a custom BBCode tag for formatting spin code [spin][/spin] in an effort to duplicate the Prop IDE. Well, it's not coming along so good.
[php]PUB main | col, loop, row, char, txt, i, start, end
LCD.start(_rxPin, _txPin, 0, 19_200)
waitcnt(clkfreq /2 + cnt)
Clear
row := 2
numChars := strsize(@_theText)
if numChars > 20
MoveTo(20-i, row)
LCD.STR(@char)
Clear
MoveTo(1, row)
LCD.STR(@char)
Clear
MoveTo(1, row)
LCD.STR(@char)
Clear
[/php]
vs [html] tags
Clear
row := 2
if numChars > 20
MoveTo(20-i, row)
LCD.STR(@char)
Clear
MoveTo(1, row)
LCD.STR(@char)
Clear
MoveTo(1, row)
LCD.STR(@char)
Clear
[/html]
tags [code]PUB main | col, loop, row, char, txt, i, start, end LCD.start(_rxPin, _txPin, 0, 19_200) waitcnt(clkfreq /2 + cnt) Clear row := 2 numChars := strsize(@_theText) repeat 'loop indefinately if numChars > 20 repeat i from 0 to 19 'increment in MoveTo(20-i, row) repeat txt from 0 to i char := byte[@_theText][txt] LCD.STR(@char) waitcnt(clkfreq / _delay + cnt) Clear waitcnt(clkfreq / _delay + cnt) repeat i from 1 to (numChars - 19) 'full line MoveTo(1, row) repeat txt from i to (i + 19) char := byte[@_theText][txt] LCD.STR(@char) waitcnt(clkfreq / _delay + cnt) Clear waitcnt(clkfreq / _delay + cnt) repeat i from (numChars-18) to numChars 'increment out MoveTo(1, row) repeat txt from i to numChars char := byte[@_theText][txt] LCD.STR(@char) waitcnt(clkfreq / _delay + cnt) Clear waitcnt(clkfreq / _delay + cnt)
