FTDI DB9-USB-D5-F connection to Basic Stamp
Hi All,
New here but have been using stamps for several years. I came across this FTDI part: DB9-USB-D5-F which is a self contained USB to Serial converted housed in a standard DB-9 connector that mounts right on a PCB.
I just tried this on a known working project of mine. I loaded the USB virtual port driver from the FTDI website and when I plug this into the laptop I get nothing.
Has anyone used this part on a basic stamp project? Any insight on circuit changes that may be required?
Thanks much,
Don
Thanks much,
Don
What I have is a custom circuit board with the BS2-PX stamp on it. The board design was originally laid out with the same RS-232 connections as depicted in the schematic for the board of education. Basically just 3 caps connected out to a DB9. This works fine using a Serial cable. I wanted to change the design to USB as many laptops are now coming with no serial port and my guys in the Field would be better served with a USB. So I stumbled upon these FTDI Modules.
I am using the Female 5Volt version, part number DB9-USB-D5-F soldered right to the PCB in place of the old Serial DB-9. But It does not see nor communicate with the laptop or Stamp.
Don
These look like a neat product...and one I could use on the BS2 OEM board.
Should you find a resolve, please post it?
