Reading a 0.6v frequency
Hey,
Trying to get a http://www.sparkfun.com/products/9768 light-2-frequency IC working but it outputs a 0.2v - 0.6v signal. Using the propeller counters in DUTY mode:
setup: (pin 4)
read:
gives:
Does the prop recognise that lower signal on a I/O pin?
Any other ideas?
Ta,
James
setup: (pin 4)
' setup light frequency counter
dira[LIGHT_FREQ]~
light_sample_period := clkfreq/5
lightFreqNextSampleTime := cnt + light_sample_period
ctra := %00110 << 26
ctra += LIGHT_FREQ
frqa := 1
read:
repeat
' light frequency sensor
if cnt-lightFreqNextSampleTime > light_sample_period
sys_lightfreq := phsa
phsa := 0
debug.dec(sys_lightfreq)
debug.tx(13)
gives:
32005958 32004902 32009574 32004902 32009574 32005958 32004902 32009574 32004902 32009574 32005958 32004902 32009574 32004902 32009574 32005958 32004902 32009574
Any other ideas?
Ta,
James
Are you sure your device is connected correctly?
After looking at the datasheet, I don't see any indication it would output such a limited range.
What voltage are you using to power it?
Edit: Phil beat me again.
If it really is a .6v level, you could put a resistor divider between the pin and +3.3V, such as 4.7K/3.3K, which will give you a .5v cutoff voltage.
thanks Phil!
