accelerometer / gyroscope
hey people
I'm working on a project where I need to check if a beacon is correctly in place between two railway tracks.
thats why we need to monitor three axes and check their angles.
We bought with the Basic Stamp a Memsic 2125 Dual-axis Accelerometer.
(item code: 28017)
http://www.parallax.com/Store/Sensors/AccelerationTilt/tabid/172/CategoryID/47/List/0/SortField/0/Level/a/ProductID/93/Default.aspx
We knew it only would monitor two axes but we took it to gain some experience with the Basic Stamp module.
So a month later we decided to buy the MMA7455 3-Axis Accelerometer Module.
(item code: 28526)
http://www.parallax.com/Store/Sensors/AccelerationTilt/tabid/172/CategoryID/47/List/0/SortField/0/Level/a/ProductID/585/Default.aspx
but it is not precise enough for our project. The max angle on the x-axis is about 2°. Our test results from the sensor where varying way to much.
I would like to know what sensor we can use best.
The results from the Dual-axis accelerometer where good, so we maybe can take that one and place a compass next to it.
Or is it better to try an other more precise accelerometer or maybe a gyroscope.
is there someone with an advice about these sensors?
I would like to hear them.
Greets
Gideon
(item code: 28017)
(item code: 28526)
Greets
Gideon
This accelerometer can be set to use all 14-bits of resolution at +/- 1G (14-bits over 2G) so if I did my math right this time (I didn't last time I tried this) the accelerometer should provide a resolution of 0.007 degrees. Assuming you could keep your instrument still enough. The math (I think) is arcsine(1 / 8191). 8191 is the max value of 13 bits (you loss one bit because of the 2G range).
I hope someone correct me if I'm wrong.
I didn't look through all of SparkFun accelerometers, I just did the math on the first one that looked like it would work.
we're probably going to try this one.
I sure can use this information.
we will keep thinking forward!
