My confusion over variables.
Hugh
The attached code runs as I hoped and intended it would. In my (feeble) efforts to reduce the size of the code I started to delete some of the variables in the VAR section that are no longer referred to in the PUBs. To my surprise, deletion of any one of the VARs against which there are three asterisks in the attached code results in the code stopping working - it compiles, loads and partially executes and then stops.
I have searched for these and am sure they are not being used in the code - should they / could they be having such an effect when they are deleted?
Any enlightenment gratefully received as always!
Hugh
BOAT14 - Archive [Date 2012.01.15 Time 17.58].zip
[B]VAR [/B] [B]byte [/B]Mode [B]byte [/B]ModeMax [B]byte [/B]oldmode [B]byte [/B]Ign [COLOR=#8b4513] ' ***[/COLOR] [B]byte [/B]Start [COLOR=#8B4513] ' ***[/COLOR] [B]byte [/B]Choke [COLOR=#8B4513] ' ***[/COLOR] [B]byte [/B]Oil [COLOR=#8B4513] ' ***[/COLOR] [B]byte [/B]Neutral [B]byte [/B]Warn [COLOR=#8B4513] ' ***[/COLOR] [B]byte [/B]rpm [COLOR=#8B4513] ' ***[/COLOR]
Hugh
Another possible culprit is that you may be accessing a variable by an index factor that is exceeding the boundaries of the var you are trying to affect, and subsequently affecting another variable(location). I did not study the code to see if this might be possible in your case.
A way to test this is, to put back in the vars, create a method to display a message if the vars are changed. On the init of the program, set all the vars to 0, then If var > 0, display message. Do this for all vars and see if you see one actually getting changed.
I am not positive on this, but I believe that when you declare vars, the program starts with longs, words, and bytes in that order when arranging them, then it uses the order in which you have placed them. Hopefully someone can correct this if needed. This may make it easier to find the stack that is robbing, if that is the case.
What surprised me today whilst trying to reduce memory usage, etc., is that the Propeller Tool included in the final binary PUBs (in other OBJects) that were not being used (as well as those that were, as expected). I had expected that the tool would identify which PUBs of other OBJects were being called and which were not, not bothering to include the latter. A few minutes commenting out a few of these 'orphan' PUBs reduced the memory usage from 4250 longs to 3670 longs, dwarfing the few longs saved by my work in the main code.
Is this commenting-out a stage of Propeller code development that I have otherwise missed? Surely the tool should be able to determine those PUBs that are required and those that are not?
The give-away for me was spotting in the Hex window strings of text that were nothing to do with my efforts.
eeprom.VarBackup(@floCount, @floCount[15] + 3) eeprom.VarBackup(@fuelrem, @fuelrem[15] + 3)Yes, it was.
(Schoolboy error)
Thank you!
