Reverse Polarity Protection for 9VDC input to Basic Stamp 2 Board
Thanks to the tremendous help from Tracy Allen, I have a circuit that creates 9 VDC from a 12 VDC motorcycle battery. I was able to plug +9VDC into (+) Vin and hook up the ground in a number of different places. I found that I eliminated the clip on battery terminal, I had to hook (-) Vss manually to a ground since the battery terminals on the board are not used in my circuit any longer.
My concern now is reverse polarity protection. I have seen several cautions about not mixing up the + and - 9VDC inputs. Is there a simple circuit that someone could recommend that provides reverse polarity protection for my case? I am certain one day I will mess it up and switch the leads my accident.
