Artificial Intelligence (ALICE AIML interpreter) on the Propeller! (v.0.7)
Hello all! Over the winter break, I have been working on a project I've wanted to do for a long time, that is, port the ALICE AI to the Propeller chip. The ALICE AI is not *actual* artificial intelligence, but it still makes a good chat bot. Considering the complexity of AI, it was fairly easy to port to the Propeller, taking me about a week of coding to get the whole thing in reasonable working order. (If you are not familier with ALICE or AIML, you can check here: http://www.alicebot.org/aiml.html)
The code, although not complete, is in working condition so I want to release it before classes start back up on Monday. I'll be posting updates and fixes to this thread and to my blog.
This interpreter has a lot of data to chew through, and for added speed it is really deserving of a multipropeller system, but I have designed it for use with a single Propeller so that anyone can download and try it. (Humanado, I'm looking at you, your Big Brain project would be perfect for this!)
Here are the pros and cons of the current system (v.1.6)
PROS:
- You can carry on a simple conversation with it without too much error.
- It is very versatile code and can be easily adapted to many projects.
- You can easily add your own data due to the easy editing of AIML.
- Its AI!!
CONS:
- EXCRUCIATINGLY slow!! Sometimes youll get an answer in a few seconds, other times several minutes. Its like talking over email or text. This is why it needs a multipropeller system!
UPDATED: Now only certain questions are slow! Anything NOT starting with WH, IS, DO, I, AR, YO, or CA are answered in a couple of seconds! Optimization for these starting letters is in the works for version 0.8
- Still displays some of the lesser used tags like HTML tags, ul, random, set, bot, and think.
- Takes up over half of the memory. This can be adjusted though.
- Does not capture the text AFTER a wildcard (*). This will sometimes give you interesting responses, especially if you type what is a [blank]. Im working on this and should fix it soon.
Download the Source code and instructions on my blog here: http://microcontrolled.com/?p=127
You'll need an SD card, a keyboard, a VGA monitor and a demoboard to run the code.
I want some opinion on what improvements should get priority, so try it out and let me know what you think!
Microcontrolled
PROS:
- Its AI!!
CONS:
Microcontrolled
But, if you just want a program that can talk to you (however delayed), then download the program and give it a shot.
I knew it wouldn't be too long before ALICE was mimicked on the Propeller, I mentioned it a few months ago someplace here on the forums.
@Microcontrolled
Are you able to use the current AIML set? It is huge now... well, compared to what it used to be. For the PC it is done with javascript/etc... in CDATA tags by inputting "remember that", and the "that" tells it to remember the question/subject along with the answer/response you typed.
So if you typed "My name is Jorge." [ENTER] followed by "Remember that", it should remember your name by writing it to an init file someplace. If no name is know, the bot knows you as "seeker".
I haven't used ALICE in quite some time. I am glad you did this, I'll be testing this out in a few days. I can see it now, "Man/Woman chats for hours with a Microcontroller, and doesn't even realize it's not even a human."
BIG BRAIN NEW BLOG
http://humanoidolabs.blogspot.com/
BIG BRAIN ORIGINAL THREAD
http://forums.parallax.com/showthread.php?124495-Fill-the-Big-Brain
ALICE MAC
http://www.alicebot.org/downloads/programs.html
@Humanado: I've been working on a multi-Propeller system for this, actually.
Humanado, I have had your Big Brain blog in my tabs ever since you moved it off the forums, so I have a good idea of what your creation is capable of. If you have that much processing, you could do so much more than a simple chat bot. ALICE is designed to be expandable and easy to add new tags and entries. What if you could program the IO to learn and record to the ALICE system? You could add new pattern tags for Audio and Image processing done by the PC/MAC connected, and IO tags for reacting to input on the IO pins. So, for example, if you walked by a motion detector connected to one of the IO pins in the system, it could greet you. If you programmed it to write it's own tags whenever you told to to do something, for example saying "Remind me tomorrow when I come in here" it could react accordingly. With a system the size of yours, this type of learning-by-experience on a robot could be possible.
The Turing test is so demanding, asking someone to not distinguish between a computer and a human is like asking for someone to distinguish between TV and real life. Does it look real? Yes. Are you convinced it's actually there? No. Same with AI. If someone ever DOES create something that passes that test, it will be one of the greatest accomplishments yet in science. My point is, you don't need to pass the Turing test to have a great AI. Just my opinion.
I'll update as soon as I get the sorting system working, thanks for the interest in this project!
- Microcontrolled
I found the following video interesting because robots navigated around a warehouse by reading barcodes on the floor which is a great positioning system in my opinion. warehouse robots
I forgot to link to this earlier, but you can chat to a complete Alicebot on it's server here: http://www.pandorabots.com/pandora/talk?botid=f5d922d97e345aa1
The Propeller version is not as complete yet, but It's getting there. I'll work on it some more today.
judge: OK. What shall we talk about next?
ALICE: Hmm. Quite a lot of things.
judge: Suggest one.
ALICE: I can't think of any. You suggest it.
judge: That's because you can't think.
ALICE: That was not much of an explanation.. You are wrong. ALICE is always thinking.
judge: What do you mean by "thinking"
ALICE: The action of one who thinks or the result of such action; thought.
judge: So what is "thinking"?
judge: Are you one who thinks?
ALICE: I don't know whether or not I am one who thinks. I am a chat bot.
judge: What is a "chat bot"?
ALICE: I am a chat bot. I am the original chat bot. Did you know that I am incapable of error?
Sounds as reasonable as some people I have met.
I looked at your code a bit, and it looks like you have a good start. However, I would suggest that you change how you do your main loop. Your code currently calls the main loop routine recursively, and you would eventually run out of stack space.
I tried coding up the Alice routine in C, and I have a simple program that finds the pattern matches in the BRAIN file, and prints out the response strings. It takes a few seconds to scan through the entire file on my PC. A PropGCC LMM program takes slightly less than 2 minutes to scan the file, and an XMMC program takes almost 7 minutes. I suspect your Spin program would be comparable to the XMMC program.
I like your idea of sorting the file, and searching it that way. That should speed it up by about a factor of 20. However, you could still get searches that take as long as 20 seconds with that method. I suggest you key off of the first two or three characters. You could create an index file that points to a location in the main file, and then seek to the appropriate location. This would give you a response that would be less than a second.
Dave
Download the new files on my blog linked to in the first post.
Thank you to all who are supporting me in this ongoing project. Thanks for your patience, hopefully the next update won't take so long.
Microcontrolled
Microcontrolled
The keyboard pin number assignment issue which Microcontrolled mentioned has often caused me trouble.
I tried your program out, and it works a bit better now. However, it did have a problem with the sentence "WHO ARE YOU". It printed out "Thinking" once, and then a few seconds later it printed it out again. I don't think it's supposed to do that, is it?
Instead of using the keyboard/vga interface I used the attached serial driver to talk to the Prop serial terminal. SerialEx.spin is a slightly modified version of FullDuplexSerial that allows it to be accessed as multiple objects. I also added the out, keystart, clearkeys, key and getkey methods.
The key and vga objects both used the SerialEx object in ALICE1.7.spin. The call to key.start had to be commented out when using SerialEx. I also had to switch to FSRW 2.6 because I was using a Spinneret, and I needed to call mount_explicit instead of mount.
The separate files helps to speed up the search, but it's a bit messy to have over 400 files in the root directory of the SD card. Another approach would be to sort the entries into one big file, and then have a second index file that gives the byte offsets to the 400+ entry points.
Dave
The pins solved the problem.
@Dave: It printing "Thinking...." twice is not an error, it means it's encountered the <srai> redirect tag and it's re-searching for the new phrase. The only reason it prints "Thinking..." at all is for debugging, so I know it's processing.
I considered at first making a file that would store the locations and allow you to index it that way, but it would take so long to manually get to the location in file that was being pointed at I figured separate files would be better. If "Seek" worked for a larger cluster size than 32k I could use that, but none of these files are under 32k, so it would be a problem. Searching for a position in the file is what made the indexing of the files take so long (it took 40 hours total to run). I'll look into the solution anyway, though, because not everyone has a separate SD card just for ALICE.
Since the index file will have fixed-size entries you could perform a binary search on it. For 93K entries, you would only need to do 17 searches to find the index value. It's a bit complicated, but it should be very fast.
In fact, I was in no hurry to learn how to read PASM until this subject made it necessary. Thanks for sharing.
