Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Write a file to PC through Prop's serial connection? — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
Ragtop
406
2012-01-13 07:17
edited 2012-01-13 08:06
in
Propeller 1
Is there a way to write a file to the PC through the prop's serial connection?
Duane Degn
10,588
2012-01-13 07:36
edited 2012-01-13 07:36
Yes, but you need software on the PC side to acept the data. Phil wrote a program to do this. I'll try to find it. (It's probably somewhere in my index (see signature).)
Duane Degn
10,588
2012-01-13 07:39
edited 2012-01-13 07:39
Thanks Google.
http://forums.parallax.com/showthread.php?134431-Access-Windows-CSV-files-from-a-Prop
Phil Pilgrim (PhiPi)
23,514
2012-01-13 07:40
edited 2012-01-13 07:40
See this thread:
Duane beat mo to it.
Ragtop
406
2012-01-13 07:44
edited 2012-01-13 07:44
Thank you!
I was thinking if I could write a html file to the pc, then there probably is a program/macro out there that would ftp that file on a regular basis.
I guess there is a way to convert a csv file to an html file.
Duane Degn
10,588
2012-01-13 07:45
edited 2012-01-13 07:45
wrote:
Duane beat me to it.
I'm very busy procrastinating this morning.
BTW, Thanks for the great program.
Rayman
16,457
2012-01-13 08:05
edited 2012-01-13 08:05
I've also got a ymodem code around that can send a file to a generic terminal program on a PC...
lfreeze
174
2012-01-13 08:06
Viewport also has a neat utility that allows writing a txt or csv file.
Larry
Sign In
Register
to comment.
Larry
