Control a 4usec switch in 1-wire
MacTuxLin
Hi All,
I need help in understanding PASM. I knew I'll have to touch on this sooner or later (was hoping the latter but), anyway, I need to control a 1-wire device that has a very tight timing requirement. Example:
Logic 1 = Low in 4.34 usec, then a High in 4.34 usec, then a Low in 4.34 usec, then a High in 25.98 usec
I need to set low at 4.34 usec but it seems I can only set either 4 usec or 5 usec? The device spec Min (4.1 usec) & Max (4.5 usec). Do I add 2 or 3 dummy instructions to achieve the 0.34 usec or do something in the _delay routine?
I've made slight changes but I think I have erred in the _newwrite sub-routine.
I'm using the 1-wire object from OBEX
Thanks a lot!
[SIZE=3][FONT=courier new]
[SIZE=2]cmd_newwrite rdlong value, t2 ' get the data byte
add t2, #4
rdlong bitCnt, t2 wz ' get bit count
if_z mov bitCnt, #1 ' must be 1 to 32
max bitCnt, #32
call #_newwrite ' write bits and exit
jmp #endCommand
[/SIZE][/FONT][/SIZE][SIZE=2][FONT=courier new]'------------------------------------------------------------------------------[/FONT]
[FONT=courier new]' input: value data bits[/FONT]
[FONT=courier new]' bitCount number of bits[/FONT]
[FONT=courier new]' output: none[/FONT]
[FONT=courier new]_writeByte mov bitCnt, #8 ' write an 8-bit byte[/FONT]
[FONT=courier new]
[/FONT]
[/SIZE][SIZE=2][FONT=courier new]_newwrite andn outa, dataMask ' set data low for 4 usec[/FONT][/SIZE]
[SIZE=2][FONT=courier new] or dira, dataMask[/FONT][/SIZE]
[SIZE=2][FONT=courier new] mov t1, #4[/FONT][/SIZE]
[SIZE=2][FONT=courier new] call #_delay[/FONT][/SIZE]
[/FONT][/SIZE]
[SIZE=2]
[/SIZE][SIZE=2][FONT=courier new] ror value, #1 wc ' check next bit[/FONT][/SIZE]
[SIZE=2][FONT=courier new] if_c andn dira, dataMask ' if 1, set data to high Z[/FONT][/SIZE]
[/FONT][/SIZE]
[SIZE=2][FONT=courier new] mov t1, #4 ' hold for 4 usec[/FONT][/SIZE]
[SIZE=2]
[/SIZE][SIZE=2][FONT=courier new] andn outa, dataMask ' set data low for 4 usec[/FONT][/SIZE]
[SIZE=2][FONT=courier new] andn dira, dataMask ' set data to high again 25 usec[/FONT][/SIZE]
[SIZE=2][FONT=courier new] mov t1, #25[/FONT][/SIZE]
[/FONT][/SIZE]
[SIZE=2][FONT=courier new] djnz bitCnt, #_newwrite ' repeat for all bits[/FONT][/SIZE]
[SIZE=2][FONT=courier new]_writeByte_ret[/FONT]
[FONT=courier new]_write_ret ret[/FONT]
[FONT=courier new]
[FONT=courier new]' input: t1 number of usec to delay (must be multiple of 4)[/FONT]
[FONT=courier new]
_delay shr t1, #2 wz ' divide delay count by 4[/FONT]
[FONT=courier new] if_z mov t1, #1 ' ensure at least one delay[/FONT]
[FONT=courier new] mov t2, delay4usec ' get initial delay[/FONT]
[FONT=courier new] add t2, cnt[/FONT]
[FONT=courier new] sub t2, #41 ' adjust for call overhead[/FONT]
[FONT=courier new]
[/FONT]
[FONT=courier new]:wait waitcnt t2, delay4usec ' wait for 4 usec[/FONT]
[FONT=courier new] djnz t1, #:wait ' loop while delay count > 0[/FONT]
[FONT=courier new]_delay_ret ret[/FONT]
[/SIZE]
Thanks a lot!
spin
38K
You would simply create some delay-values for your different timings like
delay4_34us long 347
delay28_98us long 2078
At the beginning of your signal-sequence you would store cnt into another variable and after you set the signal to a level simply call the waitcnt with the right time:
mov waittime, cnt
add waittime, delay4_34us
andn outa, dataMask
or dira, dataMask
waitcnt waittime, delay4_34us ' this is the timing for the next wait
' this has to be at the very end of your PASM-dat section
waittime res 1
The call of a subroutine is not needed and the subroutine is wasting more memory than just having some constants for the timing.
_writeByte mov bitCnt, #8 ' write an 8-bit byte _newwrite mov waittime, cnt add waittime, delay4_34us andn outa, dataMask ' set data low for 4.34 usec or dira, dataMask waitcnt waittime, delay4_34us ror value, #1 wc ' check next bit if_c mov waittime, cnt add waittime, delay4_34us andn dira, dataMask ' if 1, set data to high for 4.34 usec waitcnt waittime, delay4_34us mov waittime, cnt add waittime, delay andn outa, dataMask ' set data low again for 4.34 usec or dira, dataMask waitcnt waittime, delay4_34us mov waittime, cnt add waittime, delay andn dira, dataMask ' set data high 25.98 usec waitcnt waittime, delay28_98us djnz bitCnt, #_newwrite ' repeat for all bits _writeByte_ret _write_ret ret delay4_34us long 347 delay28_98us long 2078 bitCnt res 1 ' bit counter dataMask res 1 ' data pin mask waittime res 1I'm pretty sure johns code will show you this way. (can't check it on the smartphone to make sure)
_writeByte mov bitCnt, #8 ' write an 8-bit byte _newwrite mov waittime, cnt andn outa, dataMask ' set data low for 4.34 usec or dira, dataMask waitcnt waittime, delay_4_34us ror value, #1 wc ' check next bit if_c mov waittime, cnt ' if 1, set data to high for 4.34 usec andn dira, dataMask waitcnt waittime, delay_4_34us mov waittime, cnt andn outa, dataMask ' set data low again for 4.34 usec or dira, dataMask waitcnt waittime, delay_4_34us mov waittime, cnt andn dira, dataMask ' set data high 25.98 usec waitcnt waittime, delay_28_98us djnz bitCnt, #_newwrite ' repeat for all bits _writeByte_ret _write_ret ret
