Thermometer Sensor Probe Replacement
I would like to measure the temperature of a pipe.
-Is it possible to use a wire to wrap from either the "Digital Thermometer" chip or the Sensirion Temperature/Humidity chip around the pipe to achieve this?
-Is one better than the other?
-Or is there a better way, chip or solution for this type of application?
Thanks (in advance). Any information will be appreciated.
Not very pretty but I think it would work.
Thanks again.
This is from the DS1620 data sheet:
You may want to wait for 2nd and 3rd opinions to see if there's a prettier solution.
As the other poster mentioned, you want to get the sensor in very good contact with the pipe and exclude any external influences, such as hot air that may be in the vicinity of the sensor. I would suggest a thermal adhesive, such as http://www.arcticsilver.com/arctic_silver_thermal_adhesive.htm.
The Sensiron humidity sensor is not a good choice in this application as it is necessarily not sealed (so it can sense humidity). I would suggest something like a thermistor or an LM34/35 instead.
