E-Net Module vs Spinnernet
I am out of my element and don't grasp all the lingo, so I can't seem to compare the two. Is the Gadget Gangster e-net module doing the same web serving type functions as the spinnernet?
I have a future project on my future project list where I want to be able to track an object on a paintball field (~60 acres) and display it's position in real time on a web page.
I was thinking of using a GPS module with two xbee pros. With one of the xbee's attached to the webserver module.
Spinneret:
+ includes a realtime-clock
+ includes a SD-card-slot
+ works with 10/100base network
- needs a USB plug for programming
E-net:
- 10base network only
- realtime clock not included
+ together with propeller platform USB you don't need a USB-plug
+ SD card slot included in propeller platform USB
But you should know by yourself what your needs are. The realtime-clock is nice for logging events with a timestamp. SD-card is good if you want more than just the raw-data to be served by the module. 10 or 100 base network should not be a no-go, as the pro peller won't be able to use the full bandwidth of the 100Mbit network anyway.
To add the xbee might be easier with the gadgetgangster board. I have a small prototyping-board stacked on my gadgetgangster.
