Max 7219 Driver socket
Hey guys,
I ordered a Max 7219 in a 24 pin Dip package, hoping to use a 4 seg LED with my basic stamp, and when I received the chip, I was surprised to find the pin configuration narrower than any other IC I have ever used. I ordered a couple 24 pin Narrow Plastic Dip sockets, and none of these fit the chip. Any suggestions to where I can order sockets to fit the maxim chip?
It should be a standard 0.3" wide socket such as this:
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_39387_-1
I've been burned before ordering 24 pin sockets, as they normally default to the .6" width.
I have stacked two standard 14 pin socket to make a 28 pin socket in a pinch.
Ken
The MAX7219 is a standard 24 pin plastic DIP chip. 0.100" spacing between pins and 0.300 width spacing. Standard stuff. I've stuffed many of these in standard 0.300" , (also called narrow 24 DIP), sockets. You will be OK with the sockets you ordered. Trust me.
My chip is in spec
I didn't see this size listed officially at the Maxim web site, so the chip you have may or may not be genuine.
Here is a link to a Mill-Max SPDIP sockets datasheet:
http://www.mill-max.com/images/products/pdf/057N.pdf
Thanks again,
Ken
Do you have a closeup of the chip itself?
Ditto, let's hope it has the same pin-outs.
Asking because I found out I have a lot of them myself, but they will be difficult to use.
Before I search for adaptors or something I would really like to know if they are fake or real.
I attached a picture of the two different 7219's, the normal one to the left, the abnormal one is about one cm shorter.
You can have them if you want to, I have 10-15 of them I think.
Don't think I bother, tried the free sample thing once before, then nothing seen and nothing heard.
Ordered some 20 pcs of them on ebay and they arrived safe and sound, almost free and they all are normal!
