Measuring battery voltage with Bs1 and ADC0831
I started off with ad_conv.bas form the bs1appnotes in chapter 2 along with that same circuit. I have it all working on a breadboard.The problem I'm having is with converting the bs2 code from BAADv1.3.pdf to give a voltage.
I started to convert the following code..
I think it may have something to do with the "()" for rounding.
Trying to rewrite that segment of code is were I'm getting confused.
I included the original working code and the non working code
-dan.
Calc_Volts:
v = 16 * adcBits / 255
r = 16 * adcBits // 255
v2 = 100 * r / 255
v3 = 100 * r // 255
v3 = 10 * v3 / 255
IF (v3 >= 16) THEN v2 = v2 + 1 '<-- syntax check makes it this far when it expects
IF (v2 >= 100) THEN ' a variable
v = v + 1
v2 = 0
ENDIF
RETURN
IF (v2 >= 100) THEN
v = v + 1
v2 = 0
ENDIF
-dan.
IF v3 < 16 THEN label1
v2 = v2 + 1
label1:
IF v2 < 100 THEN label2
v = v + 1
v2 = 0
label2:
-dan
