Prop with WizNet WIZ812MJ
I just got a WIZ812MJ and I am trying to learn how to use it. It has 2 headers that are each 2x10 pins so interfacing it with a breadboard is difficult, but not impossible (any suggestions on an easier solution here I would love to hear). Ultimately, I want to find out if anyone has any code and wiring diagram that would go together to give me a simple project to get my feet wet. I am no expert with SPIN and completely ignorant of ASM, but I have built some useful projects with propellers in the past. I just need something to look at, then I can play with it and figure out how it works and how to make it do what I need.
Anything you can give me would be greatly appreciated.
Ryan Rafferty
Ryan Rafferty
Again, I really appreciate your help. I wish I was more knowledgeable with this stuff. I just love working with it and everyone on the forums are always a tremendous help.
Ryan
You don't need to buy a spinneret, the reason he mentioned it is becasue uses the same IC as the module you are using, which means you can use the spinnerets Ethernet driver to connect to your module. As far as using that module on a breadboard you won't be able to w/o building some sort of adapter. If you want to see a schematic that uses that module you can check out one of my projects here.
