Re: sumobot board Voltage capability
I've been modifying a sumobot using dc motors and esc's. We are using two motors (per side) attached to each esc and an 11.1 V LiPo battery running the two motors.
We have tied the board to one of the 11.1 V batteries. Can the sumobot board handle 11.1 V?
On another note...we are not having much luck with PING on the sumobot. Is there something I should know?
Mike, you said it will not affect my board...will it affect the PING? or...does the PING need to be on vdd?
thanks
thanks
I'm not sure how the QTIs are connected. Maybe to the AUXn connectors? In that case, the QTIs are powered from a Stamp I/O pin which can supply slightly less than 5V at currents up to about 20mA. This comes indirectly from the Sumobot's 5V regulator. These connections can't supply enough for a PING.
