Read SMS message — Parallax Forums
Read SMS message
Mikael SMikael S Posts: 60
edited 2012-01-08 12:41 in Propeller 1
Hello,
I have Wavecom GSM/GPRS modem connected via MAX2323E to my propeller. I Have no problem to send sms with AT commands, but i can't figure out how to recieve a sms message.
I use this code to send:
{{Mickes GSM 1.0}}
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
obj
  gsm: "FullDuplexSerial"
  debug: "Parallax Serial Terminal"
var
 long stack[90]
pub main
  debug.start (115200)
  gsm.start (26, 27, 0, 9600)
  waitcnt (clkfreq * 2 + cnt)
  gsm.str (string("AT+CMGS="))  'send sms command
  gsm.tx(34)                    ' send a "
  gsm.str (string("+46708667705"))  'phonenumber
  gsm.tx(34)
  gsm.tx(13)                     ' CR
  gsm.str (string("Hello World!!"))
  gsm.tx(26)                    'ctr-z to send message
  debug.str(string("Klar!"))
Is there anyone who can help me with a tip how i can recieve a message and for example show it in the Serial Terminal.
Grateful for any help!
/Mikael
  • max72max72 Posts: 1,155
    edited 2012-01-03 07:17
    Hi, download an AT manual from the web. The SMS part comes from a standard so it should work with any GSM module.
    The string to read an SMS in a memory slot N (N is an integer!!) is:
    AT+CMGR=N
    To have a list of all the stored SMS use:
    AT+CMGL="ALL"
    Let me know if it works.
    Massimo
  • rosco_pcrosco_pc Posts: 473
    edited 2012-01-03 07:24
    of SMS messages:
    AT command Meaning
    +CNMI New message indications
    +CMGL List messages
    +CMGR Read messages
    +CNMA New message acknowledgement
    Below shows a simple example
    AT
    OK
    AT+CMGF=1
    OK
    AT+CMGL="ALL"
    +CMGL: 1,"REC READ","+85291234567",,"06/11/11,00:30:29+32" Hello, welcome to our SMS tutorial.
    +CMGL: 2,"REC READ","+85291234567",,"06/11/11,00:32:20+32" A simple demo of SMS text messaging.
    OK
    AT+CMGR=2
    +CMGR: 2,"REC READ","+85291234567",,"06/11/11,00:32:20+32" A simple demo of SMS text messaging.
    OK
    OK
  • Mikael SMikael S Posts: 60
    edited 2012-01-03 07:38
    Thanks for the answers!
    I forget to tell, i'm a newbee....!
    I have the AT commands, but i can´t figure out how to read the serial string from the modem...
  • TubularTubular Posts: 4,771
    edited 2012-01-03 13:37
    On the Telits you can set AT+CNMI to a mode where it just instantly presents the SMS without having to 'poll' for it, or navigate a menu structure to get it.
    I suspect you can do the same on the Wavecom
    edited 2012-01-03 14:28
    My problem is that i cant read anything on the serial input pin. i just need some example for that!
    Is there any "trick" with the wiring of the max3232 that can go wrong? I have just wired the tx and rx directly to the prop pins, is that ok?
    Thanks!
    /Micke
    edited 2012-01-03 16:27
    Micke
    There are a couple of traps. With the Telit modules you connect TXD of the modem to TX on the prop, and RXD to RX. This is slightly counter-intuitive as often one would connect TX and RX, and RX to TX. I'm not sure if Wavecom is the same or not - which exact module are you using?
    If connecting directly to the prop you need to check the compatibility of the logic levels. Telits have 2.8v logic and a small resistor helps protect too much current from flowing. Or there are proper level shifting ICs if you want to do the job properly.
    I'll PM you code I know works with the Telit in case its helpful
    cheers
    tubular
    edited 2012-01-03 22:00
    Thank you Tubular!
    I will test the code as soon as possible ( have to work first...!)
    The modem is a wavecom fastrack M1203. I think it uses TTL because i have -5v on one of the tx or rx pins when it is not connected.
    /Micke
  • pgbpsupgbpsu Posts: 460
    edited 2012-01-04 11:52
    Hi Mikael-
    It sounds like you may be having some connection/hardware issues. Once those are resolved if you have further questions you might find some useful information in this thread or in some of the links therein.
    http://forums.parallax.com/showthread.php?129927-Help-parsing-SMS
    pb
    edited 2012-01-08 01:52
    Thanks everyone for the tips, of course it was i hardware problem, now it works!
    But, to my next problem, i use the Extended FD_Serial obj to recieve the serial strings. Is it possible to extend the recieved bytes from 16 to 25?
    I Have read on the forum thats its possible, but i cant figure out how, is there any example that i have missed?
    Thanks!
    /Mikael
    Thanks Tubular, that will do!
    Now i am stucked in next problem. When i try to use STRCOMP to parse the message from the modem with a string, i get no luck.
    The code works fine until it get to the strcomp section, it just wont send it to the right PUB.
    {{Mickes GSM 1.0}}
    CON
    obj
      gsm: "Extended_FDSerial"
    var
     byte message[16], phonenumber[16], mess1[16], mess2[16], mess3[16], mess5[16], mess6[16], mess7[16]
    dat
       on byte "on", 0
       off byte "off", 0
    pub main
    dira[2] :=1
    readmessage
    pub readmessage
    repeat
      waitcnt (clkfreq * 5 + cnt)
      gsm.rxflush
      gsm.str (string("AT+CMGR=1")) 'Read sms in first memory
      gsm.tx(13)                    'CT
      debug.str (string("Get message in memory1..."))
      debug.newline
      gsm.RxStrTime(300,@mess1)
      gsm.RxStrTime(300,@mess2)
      gsm.RxStrTime(300,@mess3)
      gsm.RxStrTime(300,@phonenumber)
      gsm.RxStrTime(300,@mess5)
      gsm.RxStrTime(300,@mess6)
      gsm.RxStrTime(300,@mess7)
      gsm.RxStrTime(300,@message)
      waitcnt (clkfreq * 1 + cnt)
      gsm.str(string("AT+CMGD=1"))      'Delete message in first memory
      gsm.tx(13)
      debug.newline
      debug.str(@mess1)
      debug.newline
      debug.str(@mess2)
      debug.newline
      debug.str(@mess3)
      debug.newline
      debug.str(@phonenumber)
      debug.newline
      debug.str(@mess5)
      debug.newline
      debug.str(@mess6)
      debug.newline
      debug.str(@mess7)
      debug.newline
      debug.str(@message)
         if strcomp (@message, string("on"))
            on2
         elseif strcomp (@message, string("off"))
            off2
      debug.str(string("no message, repeat"))
      debug.newline
    pub on2
      debug.str(string("Output2 on"))
      outa[2] :=1
      gsm.str(string("AT+CMGS="))
      'gsm.tx(34)                    ' send a "
      gsm.str (@phonenumber)  'phonenumber
      'gsm.tx(34)
      gsm.tx(13)                     ' CR
      gsm.str (string("Output on"))
      waitcnt (clkfreq * 4 + cnt)
      gsm.tx(26)
      return
    pub off2
      debug.str(string("Output2 off"))
      outa[2] :=0
      'gsm.tx(34)
      gsm.tx(13)                     ' CR
      gsm.str (string("Ouput off"))
      gsm.tx(26)
      return
