Programing Multiple Stamps?
Hello all and Happy New Year.
I am working on a project that contains 3 BS2p24-IC's, and I was wondering if there is a simple way to program each stamp seperately using only one RS-232 DB9 port? Maybe using DIP switches or a rotary switch to set which stamp to send the program to, and at the same time (pause or power off) the other two stamps so they dont execute during this process.
SIN --- SOUT --- ATN --- ATN
DB9 --- DB9 --- DB9 --- GND
For the Stamp you're programming, you'd jumper the first 3 pairs connecting the Stamp to the DB9 connector. For the other Stamps, you'd connect ATN (reset) to ground holding them in reset. Note that there's a pair of capacitors that's part of the reset circuitry on most Stamp boards. These would be on the DB9 side of the jumper block. You could use 3 x 4-pin DIP switches the same way and you'd not have the problem of losing the jumpers, but that's 12 switches that have to be set for each Stamp to be programmed.
