Need help with Boe-Bot coding terms
See ive been working on the boe-bot for a while now. I think i know what these terms are but im not sure because i want to explain to my friend what in doing and what the terms in the lines in coding do. Well bottom line ive read the manual and im not sure im correct on what these terms mean so i would like your help.
' Robotics with the Boe-Bot - BoeBotForwardThreeSeconds.bs2
' Make the Boe-Bot roll forward for three seconds.
' {$STAMP BS2}
' {$PBASIC 2.5}
DEBUG "Program Running!"
counter VAR Word
pulseCount VAR Word
FREQOUT 4, 2000, 3000
' Signal program start/reset.
FOR pulseCount = 1 TO 100 ' Loop ramps up for 100 pulses.
PULSOUT 13, 750 + pulseCount ' Pulse = 1.5 ms + pulseCount
PULSOUT 12, 750 - pulseCount ' Pulse = 1.5 ms - pulseCount
PAUSE 20
NEXT
FOR counter = 1 TO 525 ' Forward
PULSOUT 13, 850
PULSOUT 12, 650
PAUSE 20
NEXT
PAUSE 200
FOR counter = 1 TO 175 ' Rotate left - about 1, Single wheel turn
PULSOUT 13, 650
PULSOUT 12, 750
PAUSE 20
NEXT
PULSOUT 13, 750 - pulseCount ' Pulse = 1.5 ms + pulseCount
PULSOUT 12, 750 + pulseCount ' Pulse = 1.5 ms - pulseCount
PAUSE 20
NEXT
FOR counter = 1 TO 525 'Backward
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
NEXT
PAUSE 200
FOR counter = 1 TO 90 ' Rotate right - about 1, 2 wheel turn
PULSOUT 13, 850
PULSOUT 12, 850
PAUSE 20
NEXT
PAUSE 200
END
Well now what i need is know what the following terms mean and do:
- Debug
- Pulses
- Pulsout
- Freqout
and...
- what the numbers right after Pulsout mean
- what the -/+ Pulscount mean
Simple description would be helpful
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Word
pulseCount VAR Word
PAUSE 20
NEXT
PULSOUT 13, 850
PULSOUT 12, 650
PAUSE 20
NEXT
PAUSE 200
PULSOUT 13, 650
PULSOUT 12, 750
PAUSE 20
NEXT
PAUSE 20
NEXT
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
NEXT
PAUSE 200
PULSOUT 13, 850
PULSOUT 12, 850
PAUSE 20
NEXT
PAUSE 200
END
- Debug
- Pulses
- Pulsout
- Freqout
and...
