Extension wires/preassembled pins
I would like to use a connector and preassembled wires to connect the spinneret to a perfboard.
Parallax daughterboard works for small circuits, but a bigger one, or a test circuit with lot of room around is not possible, so I was looking for a connector and pre assembled wires, but I had not success with it.
Probably the right plug is the Hirose DF11-12DEP-2C, but I cannot find a pre crimped wire for it, only female ones available...
Any suggestion is appreciated.
Massimo
Massimo
DigiKey carries the pre-crimped wires and plug housing that you need. Here are some links:
http://search.digikey.com/scripts/dksearch/dksus.dll?vendor=0&keywords=DF11-12DEP-2C (plug housing)
Because of the way DigiKey prices their pre-crimped wires, it's cheaper to buy them terminated on both ends and to cut them in half, than to buy them terminated on only one end.
Thanks again.
Massimo
