RFID Card Reader inside car door? Will it work?
I'm going to be placing a RFID Card Reader inside my car door against exterior side of the door.
Will the Reader be able to pick up the signal through the sheet metal?
Andrew
Andrew
The signal of a passive RFID will not pass the metal (or the thickness) of the door.
Try to find a suitable place on the side, and enclose it in a plastic box.
Massimo
What about a window?
My rear window is tinted with 5% tint so I wouldn't be able to see the RFID Card Reader.
In case it doesn't work behind metal, it should work behind glass.
Again, be the pioneer and see if it works!
Yes, it's just sheetmetal and that's why it won't work.
I was asking the question again just to clarify, not to argue. I'm sorry if I offended you.
I didn't mean to upset anyone.
@ Publison
The RFID reader has not arrived at my house yet so I can not test it. Which is why I was asking questions.
I found a resource online that clarified even the thickness of tin foil is enough to block a weak RFID signal.
BTW, RFID toll tags and RFID tags do work through glass.
See tonytsi89
