802.11x Camera with fish eye or wide angle lens
Hello all, I have been using a D-Link BCS-920 wifi IP cam with my robots. I like it because it is low power, very light and small and the HTML/PHP is easy to hack into my own page for viewing.
The thing that I do not like is the image is very narrow and zoomed. I usually do a lot of panning and tilting to look around. I went on a few major search engines and found a couple cameras that said they were 'fish eye' lens type. Both of these cameras were pretty expensive and the more I looked the more I realized I may have to modify what I have, or find something else. For now, I'd like to find something else.
Does anyone have any recommendations?
As long as it's wifi, 5v-12v, no mic needed. I have seen them in the $1000 range, I'm looking for something way less, like $200 or so. Thanks!
Marshall Electronics
Sunex
That's the camera. The focus ring is the black plastic around the lens. If you unscrew it far enough it just stops. I'm pretty sure it won't screw back on once removed.
I'll keep looking at cameras another day, if that doesn't work I'll pull apart the DLink.
Thanks!
