SERIN program code used with Parallax GPS unit and BS2: OPEN MODE
In the demo code they setup serial com with the following code:
T4800 Con 188
Open Con $8000
Baud Con Open | T4800 'Open mode to allow daisy chaining.
Then to pull various data out of the GPS they use:
SEROUT Sio, Baud, ["!GPS", GetDate]
SERIN Sio, Baud, 3000, No_Response, [timeHRS, timeMINS, timeSEC]
After searching and reading the serial section of the manual, I did not see any references
to what the Open mode or daisy chaining would be.
I would appreciate some help on understanding the purpose and use of this Open command. Thanks
T4800 Con 188
Open Con $8000
In this case, daisy chaining just means that more than two devices are connected to the same I/O line. The term can mean something more complex as well.
