A/D converter for Memsic 2125 on BS2
I'm wondering if someone can direct me toward the proper A/D converter to use with the Memsic 2125 on a BS2? I'd like to display the output from the Memsic on a LCD.
Also, to capture/convert/display both axis values, will I need two converters?
Thanks!
Thanks!
You don't need A/D converters for the Mesmic 2125 on the BS2. You just need to read the pulses with the PULSIN command. you can read more here:
http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/SICMemsicTut.pdf
There's a whole bunch of info in the lower right of the product page under "Downloads and Resources"
