Propeller use a BOE (USB) of BS 2 to communicate whit PC ?
Hello,
I just what to no if it's possible to use a BOE (USB) ( http://www.parallax.com/Store/Microcontrollers/BASICStampDevelopmentBoards/tabid/137/ProductID/126/List/0/Default.aspx?SortField=ProductName,ProductName ) of BS2 to communicate whit the PC using a prop chip 40pin ( http://www.parallax.com/Store/Microcontrollers/PropellerChips/tabid/142/CategoryID/18/List/0/SortField/0/Level/a/ProductID/332/Default.aspx ) ?
They use the same pin RXD, TXD, DTR ---- SOUT, SIN, ATN and VSS to communicate. I just to use the integrate USB interface on the board, is that possible ?
Thank You
Thank You
Is the article you are referring to the "The Spin Zone" on page 58? It is near the bottom of the link below.
http://www.nutsvolts.com/index.php?/magazine/issue/2012/01
I think what you're asking is whether you can use a USB BOE with a 40-pin Propeller chip for programming the Propeller. The answer is not really. First of all, the Propeller uses a 3.3V power supply and 3.3V logic signals while the BOE provides a 5V power source and the USB interface provides 5V logic signals. You would need to install a 3.3V regulator and some interface parts for the serial interface. At that point, you'd probably be better off getting a PropPlug for the PC interface and still adding a 3.3V regulator. You could install a SpinStamp into the BS2 socket. This has the 3.3V regulator on the SpinStamp module along with an EEPROM and crystal for the Propeller. You'd still need a PropClip or PropPlug for programming since the SOUT, SIN, ATN interface runs at 3.3V and isn't guaranteed to work with the USB interface of the BOE (although it probably does work) and you don't use the SOUT / SIN / ATN interface for programming.
Bob
I have a 40-pin Propeller DIP as well, and a Prop Plug. I'm following the connection diagram in the Propeller Manual v1.2 to get started.
