Can Parallax serial lcd be converted to parallel?
lardom
I have a serial lcd which only displays the test screen. I replaced it but I never threw it away. I wanted to know if I could desolder the serial controller board and replace it with a ribbon cable? It may not be worth it because I would have to order a new ribbon connector.
Free with free shipping? How can you beat that?
The parallel LCD takes either 7 pins of a microprocessor in 4 bit mode or 11 in 8 bit mode (think 7-11), while RS232 serial can require as few as 1 and SPI might use only 2.
If you want, someone is likely to trade you straight across for a serial LCD.
Ravenkallen, I bought it from Parallax so I guess it's compatable.
Erco, My first thought was "Christmas came early." But I realized I've already got a parallel lcd which I never learned to use because it needs 14 pins. (I'm trying to figure it out now.)
Loopy Byteloose, I'm motivated more by the educational value than the cost. Scavenging trashed lcds could be a good thing.
My current project will use 2 steppers, a keypad, an lcd and a servo. I'd like to learn how to connect my lcd as a 4-bit device so I could save some pins.
http://forums.parallax.com/showthread.php?130172-Direct-control-of-LCD-display-an-experiment
Doc
Getting the polarity right is imperative or you immediately destroy the LCD.
