Possible improvements BoeBot PING)) IR-combination?
I'm using the basic BoeBot navigation setup, being Ping/with servo + IR led detection.
This setup is not running perfect. The led sensors are placed close to the ping servo and sometimes hits the leds while moving.
Also the leds sometimes don't detect thin/high objects like chairs and tables. Because of the blind spot it wil hit the table supports and thus damaging the leds because they stick out.
Is there a better way to navigate? Unsing the ping sensor only or using other detection then the IR leds placed on the Br. board?
Are there any suggestions to improve the detection capabillities of the BoeBot?
Thanks for all tips!
Ultrasound and IR tend to work with different surfaces and materials. By using both, you will increase your ability to detect obstacles, but thin objects like table and chair legs are really hard no matter what you use. That's why some kind of bumper switch is a good 'fail-safe'.
Thanks for the feedback! Do you have a picture of the fix? I'm not the macgyver type
If it is not too much trouble
