Webserver server restart switch
Greetings, First posts. i am just curious on actually quite a few things. I just ordered one of these babies and what I want to do is create a hard reset button for my server.
Occasionally my server locks up or i need to restart it and it does not come back up. This is a major problem because I am running its remotely. So all i can do is a "soft" reset. I have looked at commercial options at their all like 300 bucks. Which i deff don't want to spend. currently what I have in place of this is I hooked up a crappy router to my server. There are the hard reset pins on the motherboard i took those and hooked it up to some random places on the router. By power cycling the router it sends a signal to the reset switch in turn hard resting it.
Obviously not the most ideal solution and its very annoying to do because i have to another computer to remote into, log into the router webpage and reset it.
So getting to the solution. I have rummaged around on here and I found source code for a mini webserver its already presetup etc. Really in theory the only thing I need to do it create the webpage I want . do a basic authentication. then have a button that I can press reset and it sends signal to one of the outputs on the spinneret to the motherboard to reset it. hopefully this makes sense so far yes? problem is. I have never programmed one of these in my life. The most ive done is basic pic chips via USB in a class one time. im good at programming webpages not chips.
so in my head this is possible right?
Also is there anyone that can help me with this? (when i get the spinneret in about a week )
It's real easy to drive a pin high.
Tutorial
http://spinneret.servebeer.com:5000/
Example
http://www.agaverobotics.com/spinneret/controlpanel.htm
Wouldn't a better solution be to figure out why your server is becoming unresponsive?
http://tuxgraphics.org/electronics/201102/eth-network-watchdog.shtml
Spinneret Web Server Manual
Yes I saw that in the documentation. But since I do not program chips/hardware for a living I am a little confused on that. Because In the documentation it only has 12 pins on the main connector. I get that you can press the button and it will drive the LED
If you read further into the tutorial you will find you can simply send an HTTP GET with an LED parameter in the URL.
