Robotic Hand Clock, Am i out of my league....
Hello, this project im thinking about doing will be my first venture into the world of robotics and i am very excited to get started. The idea is to construct a robotic hand, controlled by servos, that will display the hour of the day. (index would be 1:00, index and middle finger would be 2:00 ect). In addition, i want to include a screen that would give the minutes and, if possible, date but that is not a must. My problem is that i lack all knowledge to get started. First of all, what will control all of this??? I saw the BASIC Stamp microcontroller and thought it might be able to control it but is that all you need? How do you program it? I can learn the language I just get lost when deciding on the "BRAIN."
Thank You for your time,
Matt
Matt
The standard answer to your question, round these parts, and it's a good one, is that you download "What's a Microcontroller".
http://www.parallax.com/Portals/0/Downloads/docs/prod/edu/28123-WAM-v3.0.pdf
You have to start somewhere.
Which microcontroller to chose depends on what it's required to do.
How many hands & fingers are you planning on having to display 12:59?
Nasty boy, Santa's watching!
Like I said previously I am completly lost, and now a little discouraged by the idea that i have to add a built in clock... The idea was to use only one hand (five fingers) to count from one to twelve. I have allready planned how to count (in my secret fashion) to 12 with one hand. However, i could not find a way to count from one to 60 for the minutes so i decided to use a display of somesort, if possible, to show the minutes. How hard is it to add a clock?
In addition i was looking at the other microcontrollers are realized that there is a description that says "PBASIC COMMANDS: 63." What does that mean only 63 lines of code?
You're not going to get this right having never done anything remotely similar.
There's a lot for you to learn.
You ought to start small.
Get a servo or two or three -- and see what it takes to get one "finger" going, given your interpretation of "finger" or "hand" or what have you.
(https://docs.google.com/viewer?a=v&q=cache:8NCWaRb2bTkJ:www.parallax.com/Portals/0/Downloads/docs/books/sw/Web-SW-v2.1.pdf+EXPERIMENTS+AND+BASIC+STAMP+SOURCE+CODE&hl=en&gl=uk&pid=bl&srcid=ADGEESh7EWUGKJmpqkcD7odnDf18g8XCTvQ4TdmkuM2Yg7PNFDEaZG6_6Sk09mTb6LD9gDHDXZfnngxpLzMA2ASTSDK8pcHSKBHrk0slbNgH0Xg9dYBR9RjgBGDrhW-Kb2TJXoQ1I7Y_&sig=AHIEtbQl8TSK4mJkTxXAddo0JcYPoy6paA)
it has tutorials and source code to run both stepper and servo-motors with a basic-stamp II module.
