smt eeprom suggestion? — Parallax Forums
electromanjelectromanj Posts: 270
edited 2011-12-16 20:14 in Propeller 1
Hello all. Does anyone have a suggestion for an smt eeprom that is compatible with the Propeller?
I'm a little hesitant about this one http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/eeprom/List/0/SortField/4/ProductID/579/Default.aspx
Not sure what package that is, but looking at it on my Prop proto boards it looks a little tiny for me to hand solder. Is there a smt size eeprom comparable to the P8X32A 44 QFP package that would work?
Thanks for any help.....
traVis
  • doggiedocdoggiedoc Posts: 2,257
    edited 2011-12-16 17:27
    I have some of those I got for bare Schmart Boards I bought at fry;s a while back. They are tiny.
    I managed OK, but I need to try again with my new headgear! LOL
    The 44 QFP prop is huge compared to that EEPROM. :D
    Paul
  • RaymanRayman Posts: 16,457
    edited 2011-12-16 17:35
    I use a rather big smt eeprom: 24FC512-I/SN
    I used a different one in the past, but it became obsolete...
    Parallax does use the tiny ones, which I don't completely understand...
    But, this one is easy to solder and works perfectly with the Prop.
  • electromanjelectromanj Posts: 270
    edited 2011-12-16 17:42
    Thank You. That looks like something I can handle. Looks like that one is 64 KB?
    traVis
    edited 2011-12-16 18:21
    I tried to find some of the 64K EEPROM I've purchased from Digi-Key in the past but they don't stock them any more.
    They do stock Rayman's suggestion. (Yes, it's 64KByte, or 512Kbit hence the 512 in the product name. 32KByte EEPROM often have a 256 in the product name.)
    edited 2011-12-16 18:23
    edited 2011-12-16 18:34
    Here is a pic of one for size reference. :D
    281 x 199 - 35K
    edited 2011-12-16 19:05
    Thanks for the link and pics Doc.
    Duane that clears that up nicely... I was wondering about the 512. Bit vs Byte gotcha.
    traVis
    doggiedoc wrote: »
    I'm pretty sure that size is referred to as TSSOP (Thin Shrink Small-Outline package). I wonder why the TSSOP chip costs so much less than the SOIC chip?
    A lot of Parallax's Propeller boards use the TSSOP size of EEPROM.
    If you want to get adventurous, you can add a second EEPROM on top of the original for expanded EEPROM storage. Just pull-up one of the address pins (I broke off pin 1 in my first attempt, good thing they're internally pulled-down).
    618 x 506 - 726K
