Electromagnet Power Transistor versus Relay
I want to turn an electromagnet capable of lifting a small iron object on and off via a microcontroller. Now obviously a relay is a small electromagnet and I use a transistor to turn it off and on. So a power transistor should work for something bigger, but given the stronger magnetic field I wonder if something nasty might happen when I turn it off. For the relay I have a diode across the coil to handle this, but how big a diode would I need to use? A relay seems safer because it provides physical isolation between the circuits.
Both methods (relay or power transistor) work fine. As you know, I'm a fan of small relays that use 20 mA and don't even need a driver transistor (most uC i/o pins can source 20 mA). Radio Shack has a 5V reed relay that a Stamp can drive directly, might work at 3.3V. Those Omron 5V latching relays I advocate work fine at 3.3V. Any small flyback/snubber diode across the coil is fine, it's the spike off the relay coil (not your electromagnet coil) that you're suppressing. 1N4001 or 1N914 work well.
I know it's hard to believe, but I already have one wired up and read to go.
LEDs on each relay are also quite useful to indicate their power on state: http://www.youtube.com/watch?v=VzbKlwc4GWs
If you need really hefty power - like 30amps at 12VDC; the 2n2222 can easily drive an automotive relay. And these are both easy to find and designed for environmental abuses that robots may have.
So, 30amps at 12 volt DC would provide 480watts of power for lifting. IS that enough? There are even heavier relays available. They jump up in cost because higher DC voltages require best design of the relay contacts.
The problem is my current gripper is limited in what it can grab. I was fiddling around with Lego Technic to build a parallel jaw gripper when I realized that an electromagnet might be a better way to go. My plan is to build Styrofoam blocks, paint them different colors, and glue a thin sheet metal square to the top. The idea is to make some objects that look substantial, but are light and easy to pick up. I would then build an electromagnet and try different voltages to determine a voltage and current that can lift these blocks reliably. At that point I will need a way to switch that a load of that size. I'm thinking I would use between 6 to 12 volts and keep it under an amp, and the relay I have from Radio Shack is rated for up to 1A at 125V AC.
Now this idea might fail spectacularly or it might work great. I don't really know. I know I can buy a better gripper, but flailing around is part of the fun for me.
Good to know, thanks.
