Program looks right but doesnt work right
Im trying to make my robot follow a line when it has a golf ball in the back (in12) and transfer it when it runs into another robot (in10) it does everything fine but after the golf ball is dropped instead of waiting like the program says it should it just continues to drive off. I am new and do not understand why it is doing this.
here is my program. any help would be appreciated.
[ Brothers robot ]
' {$STAMP BS2} ' Stamp directive.
' {$PBASIC 2.5} ' PBASIC directive.
DEBUG "Program Running!"
[ Variables ]
counter VAR Word
pulseCount VAR Byte
[ Main Routine ]
FREQOUT 4,2000,3000
DO
IF (IN12 = 0) AND (IN10 = 1) THEN ' Main DO...LOOP
GOSUB Drive
ELSEIF (IN10 = 0) THEN
GOSUB Arm_Lift
ELSE
PAUSE 5
ENDIF
LOOP
Subroutines
Drive:
qtis VAR Nib ' qti black/white states
OUTB = 11
GOSUB Check_Qtis
SELECT qtis ' Control servo speeds/directions
CASE 00 ' Rotate right
PULSOUT 13, 650
PULSOUT 12, 650
CASE 00 ' Pivot right
PULSOUT 13, 770
PULSOUT 12, 650
CASE 00 ' Curve right
PULSOUT 13, 800
PULSOUT 12, 650
CASE 10 ' Straight ahead
PULSOUT 13, 900
PULSOUT 12, 600
CASE 10 ' Curve left
PULSOUT 13, 850
PULSOUT 12, 700
CASE 11 ' Pivot left
PULSOUT 13, 850
PULSOUT 12, 770
CASE 01 ' Rotate left
PULSOUT 13, 850
PULSOUT 12, 850
CASE 11
PULSOUT 13, 900
PULSOUT 12, 600
ENDSELECT
RETURN
Arm_Lift:
servoPin CON 14 ' Set I/O pin for servo signal
FOR counter = 1 TO 150
PULSOUT servoPin, 900
PAUSE 10
NEXT
FOR counter = 1 TO 220
PULSOUT servoPin, 1150
PAUSE 20
NEXT
RETURN
Check_Qtis:
' Result -> qtis variable. 0 means white surface, 1 means black surface.
DIRB = 11 ' P7..P4 -> output
PAUSE 0 ' Delay = 230 us
DIRB = 00 ' P7..P4 -> input
' PULSOUT UnusedPin, 0 ' Delays = 208 + (Duration*2) us
qtis = INB ' Store QTI outputs in INB
RETURN
[ Brothers robot ]
[ Variables ]
counter VAR Word
pulseCount VAR Byte
[ Main Routine ]
FREQOUT 4,2000,3000
DO
GOSUB Drive
GOSUB Arm_Lift
ELSE
PAUSE 5
ENDIF
LOOP
Subroutines
Drive:
OUTB = 11
GOSUB Check_Qtis
PULSOUT 13, 650
PULSOUT 12, 650
PULSOUT 13, 770
PULSOUT 12, 650
PULSOUT 13, 800
PULSOUT 12, 650
PULSOUT 13, 900
PULSOUT 12, 600
PULSOUT 13, 850
PULSOUT 12, 700
PULSOUT 13, 850
PULSOUT 12, 770
PULSOUT 13, 850
PULSOUT 12, 850
CASE 11
PULSOUT 13, 900
PULSOUT 12, 600
ENDSELECT
RETURN
Arm_Lift:
PAUSE 10
NEXT
PAUSE 20
NEXT
RETURN
Check_Qtis:
RETURN
