Use touchbuttons to activate different sets of code - PropBASIC + P8X34A QuickStart
                    Hi! I'm relatively new to programming and especially to my new Parallax Propeller P8X34A QuickStart board. I'm building a 5x5x5 LED cube controlled by this microcontroller, and I want to start different sets of code by touching one of the buttons. For example... When you press the first touchbutton, it starts this set of code, but when you click the next button, you activate another animation... Can someone help me out? If you would be very kind, could you write the code for me, and put in "CODE GOES HERE" or something? That would be awesome.
Remember that it's PropBASIC and not Spin!
Thanks in advance,
-Jakob
Thanks in advance,
-Jakob
Jakob, Welcome to the forum. Sorry, I cann't help with the PropBASIC but if you change your mind and are looking for some Spin code to do this, I've probably got a program that would be easy to modify to do what you want.
Hopefully someone has a PropBASIC version of Beau's pad demo.
Here's a demo program. I procrastinated some other projects and heavily documented this program.
Here's what it looks like using the "Documentation" feature of the Propeller Tool.
Object "ButtonMenu111212a" Interface: PUB Setup PUB MainLoop PUB Method7 PUB Method6 PUB Method5 PUB Method4 PUB Method3 Program: 165 Longs Variable: 4 Longs Public Notes This program demonstrates using the touchpads on a QuickStart board to select which methods of a program to execute. Most of the methods may be exited by pressing pad 0 (far right pad) on the QuickStart board. The methods in this program only flash the boards LEDs. These methods are intended to illustrate some of the ways to exit a method. The exit strategies illustrated are: (Method7) A "repeat while" loop that checks a condition once per loop. If the condition is true the loop repeats. If the condition is not met, the program flow returns to the place in code immediately after the call to the method. (Method6, Method4 & Method3) One or more "abort" statements returns the flow of the program to immediately after the call to the method with an abort trap (see page 48 of Propeller Manual v1.2 for more information about aborts and abort traps). (Method5) The method must finished its programmed execution before the flow of the program returns to the place in code immediately after the call to the method. None of these exit strategies return a value (other than the default zero). The variable "delay" is used by the "Buttons" object to indicate how much time a pad's voltage should be allowed to decay prior to testing its state (to see if pad has been pressed). The variable "ledByte" makes it easier to display (with LEDs) which buttons have been pressed. The button states are held in this single byte so when used with "outa[23..16]" the LEDs corresponding to each pad will be lit. The array "button" holds the current pad states. Examples: button[0] will equal 1 while pad zero (far right pad)is pressed. button[7] will equal 0 while pad seven (far left pad) is not pressed. The object "Buttons" fills the array "button" with ones or zeros corresponding to the state (whether or not it is pressed) of each pad. __________ PUB Setup The program will start with this method "Setup" since it is the first public method. I called it "Setup" since this is where things that need to happen just once occur. (Setup or Init is a common name for this type of method.) At 80MHz (the QuickStart's default clock speed), this will be 800,000 clock cycles. _____________ PUB MainLoop MainLoop is likely where the program will speed most of its time. Touching pad 7 (far left pad) will start Method7. Pads 6 through 3 also launch corresponding methods. Touching pads 2 through 0 will only light their corresponding LED. Pad 0 (far right pad) will return the flow of the program back to this method ("MainLoop") from many of the other methods (all but Method5). ____________ PUB Method7 Method7 only checks if it should exit between the LEDs flashing sets. (About once every four seconds.) Holding the "_ExitPad" (pad 0) will trigger the exit. The program flow returns to "MainLoop" only if "_ExitPad" (pad 0) is held while the pad's state is checked (with the line "while button[_ExitPad] == 0" at the bottom of the loop. ____________ PUB Method6 Method6 ends with an abort. The method check for the abort state frequently (About four times a second.) Pressing the "_ExitPad" (pad 0) initiates the abort. Any of the above aborts returns the flow of the program back to "MainLoop". ____________ PUB Method5 Method5 will only exit after it executes five sets of LEDs flashing. There is no operator interaction. This method takes about 15 seconds to complete. By reaching the end of the method, the program flow automatically returns to the place in code immediately after the call to this method (line 100). ____________ PUB Method4 Method4 ends with an abort. The method checks for the abort state frequently. (About 8 times a second.) Pressing the "_ExitPad" (pad 0) initiates the abort. This method rotates (to the left) a pattern across the LEDs. This "abort" returns the flow of the program back to "MainLoop". ____________ PUB Method3 Method3 ends with an abort The method checks for the abort state frequently. (About 8 times a second.) Pressing the "_ExitPad" (pad 0) initiates the abort. This method rotates (to the right) a pattern across the LEDs. Methods 2 and 1 are left as an exercise for the reader.Hopefully I explained enough with comments for it to make sense.
I tried to show you how to start methods with the buttons and also how to end a method (most by pressing pad 0).
Let me know if you need part of it explained more.
