did I miss a note on floats in printf? — Parallax Forums
frank freedmanfrank freedman Posts: 1,985
edited 2011-12-11 17:36 in Propeller 1
I got an error on a simple piece of test code. Wondering if I missed something in the release notes...
no float in printf: link with -lm rounded == 0
the code is as copied from a book:
 Paste failed, but will edit later...outa time now.......
Frank
  • ersmithersmith Posts: 6,286
    edited 2011-12-11 15:55
    Frank
    In order to avoid linking in the floating point code (which is quite large), the default version of printf does not support floats. To get it, you need to link with the math library. To do this add "-lm" to the end of your final link line, e.g.:
    propeller-elf-gcc -o foo.elf foo.o bar.o baz.o -lm
    If you're not actually linking, but just compiling all the .c files, it's still the same:
    propeller-elf-gcc -o foo.elf foo.c -lm
    Eric
    Thanks, will try this when I get home.
    F
    Yep, I did miss the memo. Right in the documents.......
    F
