Question to math.h — Parallax Forums
Question to math.h
ReinhardReinhard Posts: 489
edited 2011-12-11 10:09 in Propeller 1
Sorry if I have a new question
During the port of the NMEA Lib I get problems with __isnan( double) from math.h
so I tried to reduce the problem to this snippet
#include <math.h>
// math.h ->  int __isnan(double);
// propeller-elf-gcc -mlmm  -o isnan_test.elf  isnan_test.c -lm
void main ()
    double x;
    if(__isnan(x))
and get linker error :
D:\myC\propeller_chip\gcc\isnan>propeller-elf-gcc -mlmm -o isnan_test.elf isnan_test.c -lm
C:\DOKUME~1\Reinhard\LOKALE~1\Temp\cckHbArR.o: In function `_main':
(.text+0x2c): undefined reference to `___isnan'
collect2: ld returned 1 exit status
I have no problem to compile and link this snippet with dev-cpp
best Regards
Reinhard
  • ersmithersmith Posts: 6,249
    Thank you for the bug report. That appears to be a build issue with our math library.
    We're working on a fix. You can work around it for now by using GCC's __builtin_isnan() in place of __isnan() or isnan(), e.g. by adding
    #if defined(__propeller__)
    #define __isnan(x) __builtin_isnan(x)
    #endif
    after the include of math.h.
    Eric
