Help with Bluetooth
mynet43
I have two of the Parallax Easy Bluetooth modules (#30085).
I'm doing my best to get them to talk to each other, using the code examples given in the Parallax App Note.
The sample code is given in BASIC for the BOE. I've translated this to spin for the Prop and downloaded the transmit and receive routines into the two Prop Demo boards I'm using. I'm able to send data from my PC to the receive Bluetooth module, so I know it's basically working. On the transmit module, the Bluetooth light is blinking as I tell it to send out data, so I think it's working. But they aren't communicating.
I've included debug output for each module, using two PST screens. These seem to both be working fine.
These modules are supposed to be easy to work with, using just a standard serial interface. Would someone please take a look at my code to see if you can see what I'm doing wrong? I also attached a screen shot, showing the receiver Bluetooth Device Address from my PC control panel.
Here's the receive code:
Here's the transmit code:
Thank you for your help and support.
Jim
BT-receiver.spin
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
BRX = 1 ' Bluetooth Rx
BTX = 0 ' Bluetooth Tx
baud = 38_400 ' Bluetooth serial baud rate
VAR
byte rxbyte ' Bluetooth string data
OBJ
serio : "FullDuplexSerialPlus"
debug : "FullDuplexSerialPlus"
DAT
sw_ver byte "1.02",0 ' software version number
PUB Bluetooth | count
waitcnt(clkfreq*10+cnt) ' wait until BT initialized for transparent input
initialize
repeat
debug.str(string("*")) ' show that we're here, in case stuck in rx routine
rxbyte := serio.rx ' wait for byte from Bluetooth
debug.tx(rxbyte) ' display on terminal screen
debug.str(string(" "))
if count++ == 20 ' new line every 20 characters
count := 0
debug.tx(13)
PRI initialize
serio.start(BRX,BTX,0,baud) ' start Bluetooth I/O
debug.start(31,30,0,115200) ' start debug output
waitcnt(clkfreq/4+cnt)
BT-transmitter.spin
CON
baud = 38_400 ' baud to Bluetooth device
OBJ
DAT
sw_ver byte "1.01 ",0 ' software version number
bltest byte "testing ",0
' BT receiver ID is: 00: 17: A0: 01: 6C: 94 reverse
est_lnk byte $02,$52,$0A,$08,$00,$64,$01,$94,$6C,$01,$A0,$17,$00,$01,$03
trans_cmd byte $02,$52,$11,$01,$00,$64,$01,$03 ' transparent command
initialize
debug.str(string(13,"Start Transmitting Data:",13))
count := 33 ' start with '!'
repeat
serio.tx(count) ' output Bluetooth character
debug.tx(count++) ' send same data to terminal screen
debug.str(string(" ")) ' space
if count == 127 ' stop here, last regular character
count := 33 ' reset to '!' character
debug.tx(13) ' new line to terminal
waitcnt(clkfreq+cnt) ' wait a second between outputs
PRI initialize
serio.start(BRX,BTX,0,baud) ' start Bluetooth serial output
debug.str(string(13,"Establish Link",13))
send_cmd(@est_lnk) ' establish link
waitcnt(clkfreq*5+cnt)
debug.str(string(13,"Transparent Mode",13))
send_cmd(@trans_cmd) ' transparent mode command for serial xfr
waitcnt(clkfreq*3+cnt)
PRI send_cmd(bt_cmd_adr) | i ' send transparent mode command to Bluetooth
debug.str(string(13,"Start Send Command",13))
repeat i from 0 to 63 ' send 8 command code message
serio.tx(byte[bt_cmd_adr][i]) ' send the ith code data to BT receiver
debug.hex(byte[bt_cmd_adr][i],2) ' display the code
if byte[bt_cmd_adr][i] == $03 ' end of message
quit
debug.tx(13) ' new line for terminal
debug.str(string("Exit Send Command",13))
Jim
