Basic PLX-DAQ operation
Hello,
I am a beginner Stamp user and am attempting to create a basic connection between the stamp controller and my PC to log data, but not data is being sent. I have tried stamp plot and PLX_DAQ and cannot get either to log data.
stamp plot
http://www.selmaware.com/
PLX_DAQ
http://www.parallax.com/tabid/393/Default.aspx
I am attempted to use the example code provided with the PLX_DAQ, but failed. The receive light on the dialog box is responding, but no data is being written. I am not sure if it is windows or the code.
Windows 7
Basic Stamp 2.0 REV D
Prolific USB to Serial Comm Port
stamp plot
PLX_DAQ
Windows 7
'{$STAMP BS2}
'{$PBASIC 2.5}
'***************** Simple PLX-DAQ Example *****************
' Simple PLX-DAQ routine for data.
' Program will send data on serial port to be
' accepted and placed into an Excel worksheet.
' This program also demonstrates reading the current ROW from Excel,
' and starting over again once it meets to exceeds 300.
' Check "Reset Stamp on Connect" to catch configuration data.
' January, 2007
' By Martin Hebel
' SelmaWare Solutions - [url]www.selmaware.com[/url]
' Southern Illinois University Carbondale - [url]www.siu.edu/~isat/est[/url]
'***************** PLX-DAQ data structures Used ****************
' SEROUT Sends serial data from programming port (P16)
' [ ] defines data to be sent.
' PLX-DAQ directives used:
' DATA Places data into the next row of Excel spreadsheet
' Up to 26 comma-separated values may be stored.
' Each value following "DATA," must be separated by comma-strings ","
' DATA,val1,val2,val3...Val26
' DATA,TIME, decimal value of X, Signed-Decimal value of X
' TIME Replaced by PLX-DAQ with real system time (DATE may also be used)
' in DATA directive. Column cells should be formatted for time.
' TIMER Replaced by PLX-DAQ with the seconds since last may also be used
' to show time since last RESETTIMER.
' Column should NOT be formatted for 'Time'.
' LABEL Places headings on the columns for rows A-J using up to
' 10 comma-separated labels.
' LABEL,label1,label2,...label10
' CLEARSHEET Clears columns A-J, rows 2 and on. (labels remain).
' RESETTIMER Resets the timer to 0.
' ROW,GET Requests the last row data went into.
' Accept returning data with SERIN pin, baud,[dec variable]
' ROW,SET,val Sets the row the next data set will use.
X VAR Byte 'Variable to represent data
sPin CON 16 'Serial Pin - P16, Programming port
Baud CON 84 'Baud mode for a rate of 9600, 8-N-1
'BS2P, BS2SX use 240 for 9600, 8-N-1
Row VAR Word 'Variable to hold row data
PAUSE 1000 'Allow data communications to stabilize
SEROUT sPin,Baud,[CR] 'Send a lone CR to ensure PLX-DAQ buffer is ready
'Label 3 columns with TIME, X, and SIN X
SEROUT sPin,Baud,[CR,"LABEL,Time,Timer,X,SIN X",CR]
SEROUT sPin,Baud,["CLEARDATA",CR] 'Clear all data columns (A-J) in Excel
SEROUT sPin,Baud,["RESETTIMER",CR] 'Reset Timer to 0
DO
FOR X = 0 TO 255 'Count from 0 to 255
' Send String with data for Excel
SEROUT sPin,Baud,["DATA,TIME,TIMER,", DEC X, ",", SDEC SIN X,CR]
' Request last row of data
SEROUT sPin,Baud,["ROW,GET",CR]
' Accept returning data and store into Row with 200mS timeout
SERIN sPin, Baud,200,TimeOut,[DEC Row]
' If Row is or exceeds 300, set row back to 2
IF row >= 300 THEN SEROUT sPin,Baud,["ROW,SET,2",CR]
Timeout:
NEXT
LOOP
The only thing that comes to mind is to make sure that the sheet you're trying to read data into is the first one in your Excel file. If there are multiple sheets in your file, PLX-DAQ will only read data into the first sheet. Having a second or third sheet open on your screen is not enough - the one you're trying to read to needs to be the first tab at the set of sheet tabs at the bottom of the screen..
Thanks for the quote tags. I have "Simple Data" worksheet as the first, which is what the worksheet instructions say to do. I will keep searching the forums for other similar issues. Thanks.
