Got one download of Httpserver to Eprom and then unable to reprogram Prop
I used the Google Multisocket base files and downloaded them into EPROM. The LEDS looked active (Lnk TX and RX) . I realized that I had not changed the MAC and IP to what I wanted so I edited the files and went to reload them. I got the "Unable to open Com8, no prop chip found" message. I could not find the chip with "Run, Identify" either. I opened Prop Terminal and repowered the Prop chip and I could see the services fire up, as in the Servebeer tutorial page 1. I think the Serial Terminal running on Com 8, is not allowing the Prop Tool to locate the Prop chip on Com 8. How do I get the Prop to release the Com 8 port so I can reprogram it?
Welcome to the forums!
There is a Disable/Enable button on the serial terminal. You need to disable it whenever you want to load the prop. Only the terminal or the prop tool can talk to the prop at a time.
As for marking the item resolved, I believe you can edit the original post and change the status there (click the "Edit Post" button on the original post).
No go have fun with your new "working" toy!
