Problems
I am having a problem with this code. the servo opens and closes the door but when i uncomment the GOSUB detect_intruders it wont stop beeping or open the door it gets stuck in the loop any help would be great thanks in advance.
''''''''''''''''''''''''''''''''''''''Comapny: MAGi iNDUSTRIES iNC.
'Programmer: Jeremiah Johnson
'Project: MagiIndustriesSecurity
'File: SecutirySystem.bs2
'Assingment: Final Digital Systems
'Date: Dec 7th 2011
' {$STAMP BS2}
' {$PBASIC 2.5}
'This is a single door locking system with time keeping from door lock.
'Records up to 1500 events.
'Feturing an offensive and alertive sonic subroutine for debilitating intruders.
'With single touch activation and simple event retrival.
''''''Activation{
' Push buttom button to Lock door.
' door will lock arming the sonic subroutine and recording the event
' if an intruder is detected vai the phototransducer
' sonic subroutine fires and the evnt is recorded
' Push top button to Open door
' event is recorded
' door unlocks and sonic subroutine disarmed
''''''Event_Retirval{
'1. Remove power from module
'2. Connect module to your computer
'3. Run Paralax BASIC Stamp Editor
'4. Load SecurityRetirval.bs2 into the text window
'5. Reconnect power to the module
'6. Before 6 seconds pass run the program
'7. Events will be displayed in the debug window
'' Variables ''
lckBtn VAR IN0
unlkBtn VAR IN1
open VAR Bit
detect VAR Word
intruder VAR Bit
seconds VAR Word
minutes VAR Word
hours VAR Word
days VAR Word
address VAR Word
'' Main Program ''
DO
''lock door
IF(lckBtn = 1) THEN
open = 0
GOSUB lock_door
'GOSUB detect_intruder
'GOSUB clock_start
'GOSUB record_event
ELSEIF(unlkBtn = 1) THEN
''open door
LOW 15
LOW 9
open = 1
GOSUB open_door
'GOSUB record_event
ENDIF
'' loop forever
LOOP
''''''''''''''''''''''''''''''''''''''''''''''''' Funcutions '''''''''''''''''''''''''''''''''
'locks the door
lock_door:
DEBUG "locking door", CR
PULSOUT 2, 250
RETURN
'opens the door
open_door:
DEBUG "unlocking door", CR
PULSOUT 2, 1250
RETURN
'detects intruders
detect_intruder:
HIGH 15
DO WHILE (open = 0)
PAUSE 100
RCTIME 15, 1, detect
DEBUG DEC detect, CR
'' is there an intruder
IF (detect > 4000) THEN
'intruder detected
FREQOUT 9, 1500, 2000
DEBUG "intruder detected", CR
intruder = 1
'GOSUB record_event
ELSE
'no intruder do nothing
ENDIF
LOOP
RETURN
'records time
clock_start:
''set variables
seconds = 0
minutes = 0
hours = 0
days = 0
'start timer
DO
PAUSE 1000
seconds = seconds + 1
IF (seconds = 60) THEN
minutes = minutes + 1
seconds = 0
ENDIF
IF (minutes = 60) THEN
hours = hours + 1
minutes = 0
ENDIF
IF (hours = 24) THEN
days = days + 1
hours = 0
ENDIF
LOOP
'stop timer
RETURN
'recorces events
record_event:
DO WHILE address <= 3000
WRITE address, Word open
address = address + 2
WRITE address, Word intruder
WRITE address, Word days
WRITE address, Word hours
WRITE address, Word minutes
WRITE address, Word seconds
LOOP
RETURN
''''''''''''''''''''''''''''''' End ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
