Have i killed my quickstart? only drawing 2v from USB — Parallax Forums
Dwayne DibbleyDwayne Dibbley Posts: 63
edited 2011-12-13 10:45 in Propeller 1
Hi
i was in the middle of running a program when the quickstart dropped off the usb, and now wont connect ( be seen as a com port ) measuring the voltage it is only drawing 2v from the pc and only the green power led lights up . reset button also does nothing :(
any ideas on what to check
    edited 2011-12-07 10:44
    Your voltage might be low because the board is drawing too much current. Do you have any other components connected to the QS board that might be overloading the USB power?
  • Dwayne DibbleyDwayne Dibbley Posts: 63
    edited 2011-12-07 10:45
    Nothing connected to QS
    here is the coded that was loaded
    con  _clkmode = xtal1 + pll16x                '
      _xinfreq = 5_000_000                     '
    obj
                                                            '2 Cog here
      uarts         : "pcFullDuplexSerial4FC"               '1 COG for 4 serial ports
      gps           : "GPS_IO"                              'no COG required
    var
      long  stack[50]                                       'requires stack of at least 32
      long  cog
    pub main | time
      uarts.Init
      uarts.AddPort(0,31,30,{
    }   UARTS#PINNOTUSED,UARTS#PINNOTUSED,UARTS#DEFAULTTHRESHOLD, {
    }   UARTS#NOMODE,UARTS#BAUD115200)                      'Add debug port
      uarts.AddPort(1,4,UARTS#PINNOTUSED,{
    }   UARTS#NOMODE,UARTS#BAUD115200)                      'Add gps port
      uarts.Start                                           'Start the ports
      uarts.str(0,string("Starting",13))
      gps.Init(1)                                           'use Init and then uses BackGround cog
                                                            'to process GPS receive characters
                                                            'Note the background cog isn't running
                                                            'but it doesn't seem to affect us sending
                                                            'commands to gps
      cog := cognew(BackGround,@stack) + 1                  'Start the background Cog
      time := cnt + clkfreq*2
      repeat
        if time < cnt                                       'every 2 sec check gps and camera
          if byte[gps.valid] == "A"                         'if gps is tracking pring where we are
            GPS_Output
    PRI GPS_Output
      uarts.str(0,string("GPS available",13))
      uarts.str(0,string("Latitude "))
      uarts.str(0,gps.latitude)
      uarts.str(0,string(", Longitude "))
      uarts.str(0,gps.longitude)
      uarts.str(0,string(", GPS Altitude "))
      uarts.strln(0,gps.GPSaltitude)
      uarts.str(0,string("Speed "))
      uarts.str(0,gps.speed)
      uarts.str(0,string(", Heading "))
      uarts.str(0,gps.heading)
      uarts.str(0,string(" "))
      uarts.str(0,gps.N_S)
      uarts.str(0,gps.e_w)
      uarts.str(0,string(", Satellites "))
      uarts.strln(0,gps.satellites)
      uarts.str(0,string("Time GMT "))
      uarts.str(0,gps.time)
      uarts.str(0,string(", Date "))
      uarts.strln(0,gps.date)
    pub BackGround
    'Process gps and camera receive characters
    'minimize processing in this cog, i.e. dont send to serial ports e.g. debug
    'dont call waitcnt, etc. Dont call blocking receives from serial ports - use rxcheck
      repeat
        gps.GetNMEALine
    edited 2011-12-07 11:09
    How is the GPS device connected?
    edited 2011-12-07 11:13
    Mike Green wrote: »
    3.3v off pin 38 and 39, GPS TX to pin 5 (p4) RX
    I have now connected a 9v source to 39 and 40 and have a stable 3.3v, i have also connected a external ttl usb serial to pins 35 and 33 and when conneced to the parallax serial terminal is looks like its dumping loads a garbage out, but still no reset or chip detected :(
  • hover1hover1 Posts: 1,929
    edited 2011-12-07 13:25
    I'm confused.
    Phil asked if there was anything connected, you said no. Then you told Mike there was a GPS connected, (Parallax part number?). Which GPS? What supply voltage does it need?
    Most GPS communicate at 4800 baud. Looks like you may be trying to read at 115400.
    edited 2011-12-07 13:32
    sorry for the confusion, yes there was a gps connected ( sparkfun venus 3.3v ) this has worked fine before on other code, i was trying to get the 4 serial port single cog running using the above code and just f11 loaded it to the quickstart and then f12 opened the terminal window then windows reported the com port unplugged ( USB ) and now i cannot talk to the quickstart
    i should have said with nothing connected to the quickstart it still is not recognised :)
    Thanks again
  • RaymanRayman Posts: 15,899
    edited 2011-12-07 15:10
    I'd be suspicious that you overloaded your USB port... If you only see 2V with USB connected, sounds like USB power has shut down...
    GPS units can draw a lot of power, maybe that's why...
    Anyway, I'd try a different USB port. A powered USB hub is the best idea...
    edited 2011-12-07 15:31
    Rayman wrote: »
    I thought the same, but I saw the Parallax GPS's only draw about 70ma. But.. plugging a wrong wire into a connector adjacent to to correct one on the QuickStart might release the super secret internal smoke.
    Well i left it unplugged for the last week and thought i would try it again today, plugged it in and was able to download a test program so now all working again :)
