measuring beyond 20v
Is it correct that I can't measure a 24 volt signal with the propscope?
And if yes, how would I proceed to measure anyway? Does a voltage divider change my measurements?
Am I the only one who thinks 20V is a bit silly to put the maximum for the propscope since so many PLC and other automation components run on either 12V or 24V?
In your case, divide by 2 will work. You might want to think about using 1% 10k resistors instead of 5% resistors to get a more accurate reading.
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/32220GettingStartedv1.0.pdf
Very clever.
