Install the Propeller tool on an USB memory stick?
Hi!
Is it possible to install the Propeller tool on an USB memory stick? I want to use it on a computer where I dont have permission to install software.
Magnus
Magnus
I have had great success with "Tiny Core Linux" and "Brads Spin Tool"
You can boot from a liveCD and keep your work on the USB stick.
The USB serial driver from that distribution will work with the prop plug.
Copy the "Propeller Library" to your USB stick and your good to go on just about and PC.
on newer computers that can boot from USB you could put everything in your memory stick
Perry
