programming slots
On a BS2p or BS2pe using several programming slots, is it acceptible for the program to go backwards as well as forwards through the slots such as going from slot 0 to slot 1, then to slot 5 and back to slot 1 using the RUN command? Is the backward movement to a previous slot a potential problem if coded correctly?
