PASM - Dimmer Triac Driver code help
I have been playing around with the Dimmer Triac Driver Object from the OBEX.
What I want to achieve is an inverted output i.e. the driver currently is active high output; I want to an active low output.
The object begins:
And then I changed the :loop0 line below:
To:
And further into the object:
I changed :loop2 to:
And then at the end of the code:
I changed:
to:
Using a quickstart board I have assigned port 16 to the output/triac driver pin and port 23 to for the zero crossing (active high) input.
While the original code works the modified doesn't.
Q1. What have I done wrong?
My "duh" in advance.
Cheers
The object begins:
PUB Load (BrightnessAt) '' Call this routine with address of brighness variable. '' The brighness variable should be set from 0-255, 0=full off, 255=full on. '' BrightnessAt is address of variable to pass to PASM code to set the brighness (0 - 255) ZeroPin := |< CrossDetect ' bit mask for Zero Crossing Detector Pin (Active High) OutputPin := |< Output ' bit mask for Output Pin (Active High) BrightVarAt:=BrightnessAt ' Push address of brighness into PASM code cognew(@Dimmer,@Stack) DAT { Enter with the ADDRESS of the LONG that contains the brighness level. The brightness level can be any value but it is looking for 0 = full off to 255 = full on. If the value is less than 0, it is set to 0. If the value is greater than 255, it is set to 255 }
org 0 Dimmer mov St1,OutputPin ' Set all bits for input except output pin mov dira, St1 :loop0 mov outa,#0 ' *** Turn OFF output
To:
:loop0 mov outa,#OutputPin ' *** Turn ON output
:loop1 '' Look for leading edge of zero crossing input mov st3,ina ' Read input value and st3,ZeroPin wz ' Mask off all but input bit if_z jmp #:loop1 ' Bit not high, do it again rdlong st1,BrightVarAt maxs st1,#255 mins st1,#0 mov st3,#255 ' Invert because delay makes light dimmer sub st3,st1 '' See if full on, if so, skip delay cmp st3,#0 wz if_z jmp #:loop2 '' See if full off, if so, skip delay cmp st3,#255 wz if_z jmp #:loop3 '' Calculate number of clock cycles to delay for 0-255 level '' 100% on time = 80_000_000 / 120 = total of 666_667 clock cycles (666_667/255 = 2614 counts/bit) '' Our full on = 2048+512+32+16=2608 clock cycles per level (2608*255=665_040 total clock cycles) mov st1,st3 ' 80Mhz / (1/256 x 1/120) = 2604 clock cycles per half cycle shl st3,#11 ' level x 2048 (2614 - 2048 = 566) mov st2,st1 shl st2,#9 ' level x 512 (566 - 512 = 54) add st3,st2 mov st2,st1 shl st2,#5 ' level x 32 (54 - 32 = 22) ' error of 22/2614 = insignificant but not 100% on add st3,st2 mov st2,st1 shl st2,#4 ' level x 16 (22 - 16 = 6) ' error of 6/2614 = insignificant but not 100% on add st3,st2 ' so if level = 255, skip timing and turn on immediately. add st3,cnt ' Delay until this clock value is reached '' Check to see if main delay value is reached waitcnt st3,#0 ' Wait until main count time is reached, time to turn on Triac :loop2 mov outa,OutputPin ' *** Turn ON output pin
mov outa,#0 ' *** Turn OFF output pin
:loop3 '' Look for trailing edge of zero crossing input mov st3,ina ' Read input value and st3,ZeroPin wz ' Mask off all but input bit if_nz jmp #:loop3 ' Bit high, do it again :loop4 '' Look for leading edge of zero crossing input to go HIGH again to start next cycle mov st3,ina ' Read input value and st3,ZeroPin wz ' Mask off all but input bit if_z jmp #:loop4 ' Bit not high, loop until cycle ends '' Done with this half cycle, do it again mov outa,#0 ' *** Turn OFF output pin jmp #:loop0 ZeroPin long 0 ' Pin number for Zero-Crossing Pulse (Active High) OutputPin long 0 ' Pin number for output to MOC3010M BrightVarAt long 0 ' Address of brighness variable ST1 res 1 ' Temp 1 ST2 res 1 ' Temp 2 ST3 res 1 ' Temp 1 fit 496 ' Make sure it fits within a cog's memory space
I changed:
to:
'' Done with this half cycle, do it again mov outa,#OutputPin ' *** Turn ON output pin jmp #:loop0
Cheers
Yes, the dreaded #.
Once again you have helped me. Thank you.
