Prop to Prop wireless comms using TV Broadcast mode - Is it possible ???
I was thinking (dangerous at any time!) about comms from my Quadcopter to ground to look at the data being received from the gyro (and later the accelerometer). It would be nice to display this on a small TV monitor (a car camera display which I bought for $26). So I began to think of ways to send this data.
Then I thought about the work Phil (PhiPi) has done with decoding radio signals simply with the prop. For now, I only need one way comms, and short distance <10m.
So...
Prop 1:
Uses the Broadcast mode to transmit a TV signal. Now, the video data can be simplified to monochrome and each line could be an 8 bit value. Easily done with 3 or less resistors.
Prop 2:
Acts as a receiver, demodulates and extracts the 8 bit values, and displays them on a composite TV.
I am not sure, but I think the work Phil has done would permit the decoding to be done in software quite simply with just a few parts (R, C & L).
@PhiPi: Do you think this is possible???
So...
Prop 1:
Prop 2:
Personally I prefer visualizations over data dumps, you might get some ideas from my old "On Screen Drone project" http://forums.parallax.com/showthread.php?95870-Propeller-OSD-Drone&highlight=screen+drone for some display ideas re: instrumentation.
Perry
If there is a need to receive data from the video channel then you might start by transmitting binary using
white squares at the top of the screen as the ones and spaces for the zeroes. The only simple receiver
I can think at the moment is to use a VCR as a tuner or use whatever else has an antenna input and video output.
Video channels have extremely high bandwidth and cannot fit in other frequencies.
I was about to offer that idea too, but instead of close caption data, one could send other data on the unused lines below line 20 and have a Prop with a sync separator decode your own protocol, you could possibly get 16 words sent at 60fps?
Perry
that is within the United States. Other countries may have something similar.
He is the kind of guy that studies signals and packet information for fun... WAAAYY out of my comfort zone, so I could be wrong, mis-quoting, or getting bad information to begin with. I just wanted to say, it might be a good idea to look into it a little bit before you make a mistake that will have (insert your country's federal agency here) knocking on your door. But, I do know, for short range stuff, you are probably safe as long as you don't crash any aircraft or disturb a hospital with your project.
The homepage of the site I linked to above has that notice. The bands are being slowly freed up on an area by area basis, although some are not for portable devices, only fixed. Do a "Whitespace Spectrum Search"
EDIT, sorry its not their homepage it is the overview page http://spectrumbridge.com/WhiteSpacesSolutions/Overview.aspx
