How to supply a 1mA input and read a mv output proportional to the input current
Is there a way to create a constant 1 ma input to a sensor and then read a mv output that is proportional to the input current? I am wanting to run a pressure sensor and the supplier says the nominal input is 1.0 mA (1.5 ma max) and the output is 0 to 50 mv but it proportional to the input current. I would like to store the input and output data to make decisions for control of another device. I would like to store the last 10 readings in such a way that they will be in memory when the board is disconnected from power and then powered back up again. The schematic of the pressure is located at this website: http://meas-spec.com/downloads/23_33_Std.pdf
I know you're pretty new to the forum -- welcome, by the way! -- so you get a bye this time. But, in the future, please be aware that posting the same question in more than one location is against forum rules. M'kay?
BTW, if you ever want to have one of your threads moved, just click the little triangular "!" below your first post, and send a request to the moderators to move it for you.
If you end up with the quad op-amp that came up in your other thread, then it is possible to use that with a voltage source to regulate the 1.5 mA current for the bridge. Circuit attached.
